社区活动 技术论坛 搜索孔的程序
搜索孔的程序
2013-08-23 11:11 284 0 5
一个平板有好多孔,程序目的为了检测是否有漏加工的孔 SNSLCT/SA(P1_0_0P0_0) F(PLA_1)=FEAT/PLANE,CART,-630.2310,-932.1222,-943.3087,0.00148781,-0.00115741,0.99999822 MEAS/PLANE,F(PLA_1),4 PTMEAS/CART,-688.5620,-908.7690,-943.1901,0.00400397,0.00000000,0.99999198 PTMEAS/CART,-688.5820,-931.5615,-943.2256,0.03001612,0.00500269,0.99953690 PTMEAS/CART,-572.1880,-911.2810,-943.3724,-0.01301097,0.01201013,0.99984322 PTMEAS/CART,-571.6350,-976.9629,-943.4436,0.02801557,0.06403558,0.99755430 ENDMES DECL/DOUBLE,PLA_1_I,PLA_1_J,PLA_1_K PLA_1_I=OBTAIN/FA(PLA_1),6 PLA_1_J=OBTAIN/FA(PLA_1),7 PLA_1_K=OBTAIN/FA(PLA_1),8 F(CIR_1)=FEAT/CIRCLE,INNER,CART,-604.7864,-937.7296,-945.1245,PLA_1_I,PLA_1_J,PLA_1_K,30.0039 MEAS/CIRCLE,F(CIR_1),4 PTMEAS/CART,-619.7876,-938.2775,-945.1040,0.99996593,0.00800774,-0.00200193 PTMEAS/CART,-605.7654,-922.7594,-945.1170,0.02998651,-0.99955030,0.00000000 PTMEAS/CART,-589.8060,-936.9540,-945.1175,-0.99995950,-0.00899964,0.00000000 PTMEAS/CART,-619.7575,-936.9585,-945.1180,0.99992786,-0.01201115,0.00000000 ENDMES CONST/CIRCLE,F(CIR_1),PROJCT,FA(CIR_1),FA(PLA_1) DECL/DOUBLE,PLA_1_I,PLA_1_J,PLA_1_K PLA_1_I=OBTAIN/FA(PLA_1),6 PLA_1_J=OBTAIN/FA(PLA_1),7 PLA_1_K=OBTAIN/FA(PLA_1),8 F(CIR_2)=FEAT/CIRCLE,INNER,CART,-605.3495,-969.6852,-945.3369,PLA_1_I,PLA_1_J,PLA_1_K,11.9500 MEAS/CIRCLE,F(CIR_2),4 PTMEAS/CART,-605.6990,-975.6584,-945.3410,-0.03701164,0.99931433,-0.00100031 PTMEAS/CART,-610.5306,-972.3121,-945.3405,0.99903147,-0.04400139,0.00000000 PTMEAS/CART,-605.5950,-963.7070,-945.3350,0.01099933,-0.99993901,0.00099994 PTMEAS/CART,-599.4786,-968.7050,-945.3330,-0.99985553,-0.01699754,0.00000000 ENDMES CONST/CIRCLE,F(CIR_2),PROJCT,FA(CIR_2),FA(PLA_1) DECL/DOUBLE,PLA_1_I,PLA_1_J,PLA_1_K PLA_1_I=OBTAIN/FA(PLA_1),6 PLA_1_J=OBTAIN/FA(PLA_1),7 PLA_1_K=OBTAIN/FA(PLA_1),8 F(LIN_1)=FEAT/LINE,BND,CART,-604.7864,-937.7296,-945.1245,-605.3495,-969.6852,-945.3369,PLA_1_I,PLA_1_J,PLA_1_K CONST/LINE,F(LIN_1),BF,FA(CIR_1),FA(CIR_2) D(DAT_1) = DATSET/FA(PLA_1),ZDIR,ZORIG,FA(LIN_1),XDIR,YORIG,FA(CIR_1),XORIG,YORIG,ZORIG RECALL/D(DAT_1) MODE/PROG,MAN SNSET/CLRSRF,FA(PLA_1),20.0000 GOTO/30.9185,2.7978,36.1900 DECL/CHAR,64,FILENAME,CIRNAME,FILE1,PTNAME DECL/INTGR,I,PtNum $$获取圆心坐标和直径 DECL/REAL,PX,PY,Pd $$未加工的圆数 PtNum=ASSIGN/0 FILENAME=PROMPT/'ENTER THE NAME OF THE DATA FILE WITHOUT EXTENSION(请输入一个数据文件名!)' FILE1=ASSIGN/CONCAT('E:\',FILENAME,'.TXT') DID(F1)=DEVICE/STOR,FILE1 OPEN/DID(F1),DIRECT,INPUT DO/ I,1,5,1 READ/DID(F1),PX,PY,Pd BADTST/ON SNSET/SEARCH,6.0000 PTNAME=ASSIGN/CONCAT('POI_',STR(I)) F(@PTNAME)=FEAT/POINT,CART,PX,PY,0,0,0,1 MEAS/POINT,F(@PTNAME),1 PTMEAS/CART,PX,PY,0 ENDMES $$ check to see if the point feature was successfully measured. $$ if not sucecess mesure the hole IF/(BADPT()) SNSET/RETRCT,1.0000 SNSET/APPRCH,1.0000 DECL/DOUBLE,PLA_1_I,PLA_1_J,PLA_1_K PLA_1_I=OBTAIN/FA(PLA_1),6 PLA_1_J=OBTAIN/FA(PLA_1),7 PLA_1_K=OBTAIN/FA(PLA_1),8 CIRNAME=ASSIGN/CONCAT('cir1_',STR(I)) F(@CIRNAME)=FEAT/CIRCLE,INNER,CART,PX,PY,-2,PLA_1_I,PLA_1_j,PLA_1_k,pd MEAS/CIRCLE,F(@CIRNAME),4 ENDMES CONST/CIRCLE,F(@CIRNAME),PROJCT,FA(@CIRNAME),FA(PLA_1) ELSE PtNum=ASSIGN/PtNum+1 ENDIF BADTST/OFF ENDDO CLOSE/DID(F1) ENDFIL
2013-08-23 11:11
超级程序,学习了
2013-08-23 17:53
quindos 这个软件没有用过
2013-08-24 21:37
主,这是哪个测量软件用的啊
2013-08-25 10:43
其实PC_DMIS里面有个功能就是以DMIS形式显示程序,就和上面的差不多了
2013-08-26 07:54
