社区活动 技术论坛 关于生成hpgl格式有关问题
关于生成hpgl格式有关问题
2005-09-11 00:12 232 0 10
如何把plot中生成的图形转换成hpgl格式的文件,望高手指点!
2005-09-11 00:12
{/gg}
2005-09-14 14:21
QUINDOS中还没有实现这样的功能.
2005-09-16 19:01
QUINDOS中已有实现这样的功能 以下是我从他们官方网站上摘录下的内容: Plotting with PlotViewer For companies committed to maintaining inspection records for longer periods of time the management of the large amount of hard copy output can be time consuming and inefficient. An effective solution is to save and maintain inspection records on a networked computer. As and when inspection records are required, the user has the choice of viewing the contents on screen, printing them, sending them via E-mail or saving them to a suitable media.. Printing and plotting to a file was implemented in Quindos at a very early stage, however, the resulting file could only be printed using a compatible printer, or viewed using a program with the correct drivers. Description The QPlotViewer is a software package which can be used to view hpgl files created in Quindos. The information contained in the hpgl file can be saved in various formats compatible with a wide range of applications. The resulting files can be sent to customers and suppliers who can use their own Windows-based programs to view and print the files. QPlotViewer can be used to create files which can be read by other software packages. Prerequisites hpgl-Files created with Quindos independant of the Quindos version (VMS,SCO,Xact,Q6) Operating systems Windows NT4.0 / SP6a, Windows 2000 and Windows XP QPlotViewer needs Microsoft .NET Framework 1.1 which can be downloaded from Microsoft's web pages .NET Framework Redistributable 1.1 QPlotViewer in a fully working version Version 1.0.1343 only executable Setup english version1343 Setup for Windows-Installer
2005-09-16 20:54
我问问公司其他同事,请耐心等待。
2005-09-17 18:20
不知道问得怎么样了?
2005-11-25 18:40
这个问题我已解决,在print设置中选输出到文件,输出后把文件的扩展名改为hpgl,就可以用QPlotViewer程序打开还可以转成bmp,jpeg等格式。
2006-01-10 19:59
{/qiang}
2007-03-05 12:28
提供一下QPlotViewer和Microsoft .NET Framework 1.1 下载吧! 我的邮箱:chasedreamman@126.com
2007-03-06 09:36
http://www.mtwz.com/downloads/PlotViewer_1343.zip http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=262D25E3-F589-4842-8157-034D1E7CF3A3
2007-03-08 19:19
