社区活动 技术论坛 导出数据到文件
导出数据到文件
2004-12-02 12:02 485 0 14
Hi there. I have problem with data export. I want to make quindos exporting measured data to file, but in specific order. I would like to have all measured dimensions in one line (separated by spaced or tabs) and next measurements in next lines. exampe of desired file: data time dimension_1 dimension_2 ..... (measurement1) data time dimension_1 dimension_2 ..... (measurement2) data time dimension_1 dimension_2 ..... (measurement3) Anyone has any idea how i can make it? My email is padiina@vp.pl . Thanks for any help
所有回贴(14)
2004-12-02 12:02
1.你可以定义UVS数据. 如DFNUVS... 然后将所有数据拷贝到UVS. UVS的特点就是自由编辑数据输出格式. 2.定义队列 3.定义HRC DFNHRC.. PUTVALS.....
2004-12-02 13:19
I tried to do it using HRC-s, after DFNHRC i have no idea how to put value into HRC using PUTVAL. It keep telling me that "Index out of range in HIS(I)" DFNHRC (NAM=ALA, FLD=(A,B,C,D), FLG=(5,4,5,4)) PUTVAL (OBJ=ALA, DSC=A, TYP=HRC, VAL=10)) What can be wrong in this? Thanks for any help Edited by - padlina on 2004/12/03 06:41:02
2004-12-02 20:21
用CRSUBTYP将你定义的数据初始化.
2004-12-03 08:43
hello,i have written a thesis about your question. i will send to you by email next mondey.
2004-12-04 09:01
To solve this problem.,you can define a UVS object ,for example,Special data format to saving pitch and runout evaluation of bevel gear can be defined by command DFNUVS . by way of illustration,program: SPIRBV Or …… MECIRPI BVPITCH DFNQUE (NAM=$QUE$LEFT, MBR=ELE:(PI_RES(1),PI_RES(3)......), DEL=Y) DFNQUE (NAM=$QUE$RIGHT, MBR=ELE:(PI_RES(2),PI_RES(4)......), DEL=Y) FCNVAL (NAM=MAX$PI, TYP=MAX, VAR=$QUE$LEFT.ACT.A,POS=IDX$LEFT) FCNVAL (NAM=MAX$PI, TYP=MAX, VAR=$QUE$LEFT.ACT.A, POS=IDX$RIGHT) …… !Reading the parameters of element PI_RES queue and storing them in Real-Variables descriptor (e.g.: A,B,C,etc.). GETVAL (NAM=CUM$LEFT,OBJ=PI_RES(1).ACT,DSC=A,TYP=ELE) GETVAL (NAM=CUM$RIGHT,OBJ=PI_RES(3).ACT, DSC=A,TYP=ELE) GETVALS (OBJ=PI_RES(2).ACT,TYP=ELE, RDS=(A,B,C), REA=(IND$LEFTAVG,IND$LEFTMAX,IND$LEFTMIN) GETVALS (OBJ=PI_RES(4).ACT, TYP=ELE, RDS=(A,B,C), REA=(IND$RIGHTAVG,IND$RIGHTMAX,IND$LRIGHTMIN) ! Editing text for macro mask. EDTTXT (NAM=MSK) ! The text object is subsequently converted with CNVTXT CNVTXT (NAM=MSK) ! Define UVS variable DFNUVS (NAM=RES$OUT, DSC=MSK) ! Rewritting the fields of universal object RES$OUT.,these fields are described by strings (e.g.: a,b,c,etc.). PUTVALS (OBJ=RES$OUT, TYP=UVS, RDS=(h,i,a,b,c,d,e,f,g), VAL=(IND$LEFTAVG,……) LISUVS (NAM=RES_OUT, MSK=MSK) Result data are as follows: Bevel gear evaluation listing of pitch & runout Number of teeth : 22 Individual pitch left : MAX:0.040 / MIN:0.010 / AVG:0.025 Cumulative pitch left : MAX:0.050 Individual pitch right: MAX:0.050 / MIN:0.020 / AVG:0.035 Cumulative pitch right: MAX:0.050 Runout : 0.025 ----------------------------------- quindos BEVELGR -------------------------------------- NOTE:1,This program is only used for prelection,not used for measurement. 2,You can create ASCII file with command CNVCONDG ,about the particular information of this command you can read the reference manual of quindos option DGSURF .
2004-12-07 17:27
Thank you very much. Do u know where i can find some manuals? We have recived some with our quindos version, but they are very bad. Its quindos 6.0
2004-12-08 10:12
To obtain this manual,you must refer to Qianshao Technology CO.,LTD. And then, you must affirm whether your software includes the option DGSURF with command TESTPDC.
2004-12-08 17:59
I have already checked in licence manager and we dont have DGSURF option. I have one more question about macro masks (MSK). All i know is to how export text (written in mask) and data (using $AAA.AAAA$ $BB.BBB$ etc). Are there any other useful features there? (like, how to export current date and time or variable name etc). How to export only major digits (we have 1234.5678 and i want to export only 1234) If it is not possible, where quindos store date/time? I could waste 6 var fields to store data/time and use simple export mask. About that HRC (command ENBHRC) U told me earlier, i tried to use it, but i have no idea how to put values into it. It has date and time, looks like nice tool for any kind of export. Thanks for any help!
2004-12-17 14:29
What's mean's UVS?HOW to use?
2004-12-18 22:31
