社区活动 技术论坛 短圆弧的测量方法
短圆弧的测量方法
2004-08-05 21:12 397 0 2
实际工作中经常会遇到短圆弧的测量,下面给出测量方法: ! Define the curve segment DFNCV2D (SGM=SGM1,TYP=ARC,STA=(..),END=(...),PTS=20,DEL=Y,CSY=CSY,OFS=5) ! Check/edit the curve segment EDTSGM2D (NAM=SGM1) ! Generate probing points of the complete contour GENCV2D (NAM=SCAN1,SGM=SGM1,DEL=Y,CLW=N,INO=O) ! Check the probing points EDTNPT (NAM=SCAN1) ! Create a norminal element for comparsion EXCHNG (NAM=SCAN1,TYP=MOV) ! The actual points are copied to a new element CPYAPT (FRM=SCAN1,TO=SCAN$NOM,DEL=Y) ! Mesure contour ME2DE (NAM=SCAN1) ! Calculate contour RCOR2D (SRC=SCAN1,DST=SCAN2...) ! Bestfit the actual points BFITPT(ACT=SCAN1,NOM=SCAN$NOM,RES=SCAN3,TRA=TRA$SGM,ETY=PD,MXI=100) ! Compare the mesured profile ACNOPT (ACT=SCAN3,NOM=SCAN$NOM,RES=RES1,ETY=PD) ! GETVAL(NAM=REA1,OBJ=RES1.ACT,DST=E) GETVAL(NAM=REA2,OBJ=RES1.ACT,DST=F) GETVAL(NAM=REA3,OBJ=RES1.ACT,DST=D) LISEXP (NAM=(REA1,REA2,REA3)) ! CVMSKTXT (MSK=PM$APTTT,TXT=TXT) DELTXT (NAM=GDBSTA:PM$APTTT,CNF=Y) EDTTXT TXT CNVTXT TXT SET (NAM=GDBSTA:PM$APTTT,STR=TXT) !Output result points LISAPT RES1 有些朋友可能会用扫描的办法,再BFIT2D,ACNO2D,但是我单位机器的定位精度高于扫描精度,大家可以做一下试试 Edited by - 刘彬 on 2004/08/05 21:16:35
所有回贴(2)
2004-08-05 21:12
高啊!!
2004-08-15 19:47
