社区活动 技术论坛 同心度怎么测
同心度怎么测
2016-04-20 16:31 260 0 5
[attachimg]6413[/attachimg] 如图测量中间圆棒和外圆的同心度,我测量的方法是测圆柱体,外圆是同一高度的七个点构造圆。测出来有0.17这样测的准吗? 零件名: 0 修订号: 序列号: 统计计数: 1 启动 =坐标系/开始,回调:,列表=是 坐标系/终止 模式/手动 飞行/开,3 格式/文本,选项, ,标题,符号, ;标称值,公差,测定值,偏差,超差, , 加载测头/1-30 测尖/T1A0B0, 支撑方向 IJK=0, 0, 1, 角度=0 柱体1 =特征/柱体,直角坐标,外,最小二乘方 理论值/<176.2956,113.4782,-563.4349>,<0.0006761,0.000619,-0.9999996>,2.9909,3.9341 实际值/<176.2956,113.4782,-563.4349>,<0.0006761,0.000619,-0.9999996>,2.9909,3.9341 测定/柱体,8 触测/基本,常规,<177.7335,113.8798,-561.4696>,<0.9629907,0.2695333,0.000818>,<177.7335,113.8798,-561.4696>,使用理论值=是 移动/圆弧 触测/基本,常规,<176.2553,114.9719,-561.469>,<-0.0261203,0.9996586,0.0006011>,<176.2553,114.9719,-561.469>,使用理论值=是 移动/圆弧 触测/基本,常规,<174.8547,113.8782,-561.4686>,<-0.9632884,0.2684683,-0.0004851>,<174.8547,113.8782,-561.4686>,使用理论值=是 移动/圆弧 触测/基本,常规,<176.4529,111.9904,-561.4688>,<0.1060625,-0.9943593,-0.0005438>,<176.4529,111.9904,-561.4688>,使用理论值=是 移动/圆弧 触测/基本,常规,<176.5732,112.0084,-565.4001>,<0.1845317,-0.9828264,-0.0004836>,<176.5732,112.0084,-565.4001>,使用理论值=是 移动/圆弧 触测/基本,常规,<177.7336,113.8942,-565.4008>,<0.9607579,0.2773872,0.0008213>,<177.7336,113.8942,-565.4008>,使用理论值=是 移动/圆弧 触测/基本,常规,<175.9759,114.9414,-565.4008>,<-0.21453,0.9767173,0.0004595>,<175.9759,114.9414,-565.4008>,使用理论值=是 移动/圆弧 触测/基本,常规,<174.8902,113.9859,-565.4003>,<-0.9408646,0.3387825,-0.0004265>,<174.8902,113.9859,-565.4003>,使用理论值=是 终止测量/ A1 =坐标系/开始,回调:启动,列表=是 建坐标系/找平,Z正,柱体1 建坐标系/平移,Z 轴,柱体1 坐标系/终止 点1 =特征/点,直角坐标 理论值/<137.8051,-113.5308,3.4143>,<-1,0,0> 实际值/<137.8051,-113.5308,3.4143>,<-1,0,0> 测定/点,1 触测/基本,常规,<137.8051,-113.5308,3.4143>,<-1,0,0>,<137.8051,-113.5308,3.4143>,使用理论值=是 终止测量/ 点2 =特征/点,直角坐标 理论值/<151.8567,-83.4017,3.4052>,<-1,0,0> 实际值/<151.8567,-83.4017,3.4052>,<-1,0,0> 测定/点,1 触测/基本,常规,<151.8567,-83.4017,3.4052>,<-1,0,0>,<151.8567,-83.4017,3.4052>,使用理论值=是 终止测量/ 点3 =特征/点,直角坐标 理论值/<182.1923,-75.5641,3.4208>,<0,1,0> 实际值/<182.1923,-75.5641,3.4208>,<0,1,0> 测定/点,1 触测/基本,常规,<182.1923,-75.5641,3.4208>,<0,1,0>,<182.1923,-75.5641,3.4208>,使用理论值=是 终止测量/ 点4 =特征/点,直角坐标 理论值/<209.5204,-94.7004,3.4517>,<1,0,0> 实际值/<209.5204,-94.7004,3.4517>,<1,0,0> 测定/点,1 触测/基本,常规,<209.5204,-94.7004,3.4517>,<1,0,0>,<209.5204,-94.7004,3.4517>,使用理论值=是 终止测量/ 点5 =特征/点,直角坐标 理论值/<211.0347,-128.3514,3.4736>,<1,0,0> 实际值/<211.0347,-128.3514,3.4736>,<1,0,0> 测定/点,1 触测/基本,常规,<211.0347,-128.3514,3.4736>,<1,0,0>,<211.0347,-128.3514,3.4736>,使用理论值=是 终止测量/ 点6 =特征/点,直角坐标 理论值/<185.7573,-150.1477,3.4698>,<0,-1,0> 实际值/<185.7573,-150.1477,3.4698>,<0,-1,0> 测定/点,1 触测/基本,常规,<185.7573,-150.1477,3.4698>,<0,-1,0>,<185.7573,-150.1477,3.4698>,使用理论值=是 终止测量/ 点7 =特征/点,直角坐标 理论值/<152.2471,-143.2926,3.4427>,<0,-1,0> 实际值/<152.2471,-143.2926,3.4427>,<0,-1,0> 测定/点,1 触测/基本,常规,<152.2471,-143.2926,3.4427>,<0,-1,0>,<152.2471,-143.2926,3.4427>,使用理论值=是 终止测量/ 圆1 =特征/圆,直角坐标,外,最小二乘方,否 理论值/<175.9619,-113.2036,3.4397>,<0,0,1>,76.485 实际值/<175.9619,-113.2036,3.4397>,<0,0,1>,76.485 构造/圆,最佳拟合,2D,点7,点1,点2,点3,点4,点5,点6,, 局外层_移除/关,3 过滤器/关,UPR=0 DIM 同心度1=同心度圆 圆1 至 柱体 柱体1 单位=毫米 ,$ 图示=关 文本=关 倍率=10.00 输出=两者 AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 0.0000 0.0100 0.0000 0.1760 0.1760 0.1660 --------> 尺寸信息/同心度1;图标,尺寸标识,特征标识,垂直,水平, ,$ 标题,轴图示;测定值, , , , [attachimg]6414[/attachimg] [attachimg]6414[/attachimg]
2016-04-20 16:31
个人认为你测量的不对,同心度是测量2个圆的圆心的偏离,同时他们是2维元素,同轴度是3维元素,按你测量的,基准A是3维元素,圆1构造的2维元素,评价不对,要么你测量2个圆评价同心度,要么测量2个圆柱,评价同轴度,
2016-04-21 09:14
方法1. 测量好基准A后, 再在外圆不同的高度上测量圆(至少2个,最上面和最下面) 然后评价圆对A的同心度, 取最大的值. 方法2. 外圆测量圆柱, 评价两个圆柱的同轴度
2016-04-21 12:25
编个简易程式自动跑,不要用手动测量元素。试试看
2016-04-22 23:09
这么的不对吧,同意二楼的观点
2016-04-24 11:01
