社区活动 技术论坛 高手帮忙修改下,测点创建后,怎么修改他的XYZIJK的值
2015-12-17 14:18 222 1 5
Sub auto() Dim pcd As Object Dim pp As Object Dim cmds As Object Dim cmd As Object Dim checktype As Integer checktype = 602 Dim hang As Integer hang = Cells(Rows.Count, 1).End(xlUp).Row Set pcd = CreateObject("PCDLRN.Application.4.2") Set pp = pcd.ActivePartProgram Set cmds = pp.Commands Dim a As Integer For a = 9 To hang Set cmd = cmds.LastCommand cmds.InsertionPointAfter cmd Set cmd = cmds.Add(checktype, True) cmd.ReDraw ' Set ÀíÂÛÖµX RetVal = cmd.PutText(Cells(a, 3), THEO_X, 0) ' Set ÀíÂÛÖµY RetVal = cmd.PutText(Cells(a, 4), THEO_Y, 0) ' Set ÀíÂÛÖµZ RetVal = cmd.PutText(Cells(a, 5), THEO_Z, 0) ' Set ÀíÂÛÖµI RetVal = cmd.PutText(Cells(a, 6), THEO_I, 0) ' Set ÀíÂÛÖµJ RetVal = cmd.PutText(Cells(a, 7), THEO_J, 0) ' Set ÀíÂÛÖµK RetVal = cmd.PutText(Cells(a, 8), THEO_K, 0) ' Set ²â¶¨X RetVal = cmd.PutText(Cells(a, 3), MEAS_X, 0) ' Set ²â¶¨Y RetVal = cmd.PutText(Cells(a, 4), MEAS_Y, 0) ' Set ²â¶¨Z RetVal = cmd.PutText(Cells(a, 5), MEAS_Z, 0) ' Set ²â¶¨I RetVal = cmd.PutText(Cells(a, 6), MEAS_I, 0) ' Set ²â¶¨J RetVal = cmd.PutText(Cells(a, 7), MEAS_J, 0) ' Set ²â¶¨K RetVal = cmd.PutText(Cells(a, 8), MEAS_K, 0) ' Set Ä¿±êX RetVal = cmd.PutText(Cells(a, 3), TARG_X, 0) ' Set Ä¿±êY RetVal = cmd.PutText(Cells(a, 4), TARG_Y, 0) ' Set Ä¿±êZ RetVal = cmd.PutText(Cells(a, 5), TARG_Z, 0) ' Set Ä¿±êI RetVal = cmd.PutText(Cells(a, 6), TARG_I, 0) ' Set Ä¿±êJ RetVal = cmd.PutText(Cells(a, 7), TARG_J, 0) ' Set Ä¿±êK RetVal = cmd.PutText(Cells(a, 8), TARG_K, 0) ' Set ²âµãÃû RetVal = cmd.PutText(Cells(a, 2), ID, 0) ' Set Display Hits Item 1 = NO RetVal = cmd.PutText("NO", DISPLAY_HITS, 1) ' Set Show Details Item 1 = NO RetVal = cmd.SetToggleString(1, SHOW_DETAILS, 1) ' Set Coordinate Type = RECT RetVal = cmd.SetToggleString(1, COORD_TYPE, 0) ' Set Snap Type = NO RetVal = cmd.SetToggleString(1, SNAP_TYPE, 0) ' Set Find Nominal Axis = NONE RetVal = cmd.SetToggleString(1, FIND_NOM_AXIS_TYPE, 0) ' ÒÆ¶¯ÀàÐÍ RetVal = cmd.SetToggleString(1, MOVE_TYPE, 0) ' ÒÆ¶¯¾àÀë RetVal = cmd.PutText("0", F_AUTOMOVE, 0) ' ºñ¶ÈÀàÐÍ RetVal = cmd.SetToggleString(1, THICKNESS_TYPE, 0) ' ºñ¶È RetVal = cmd.PutText("0", F_THICKNESS, 0) Next End Sub
2015-12-17 14:18
VBA 编的 看例子用RetVal=cmd.puttext()来修改,改不了啊?
2015-12-17 15:47
可以参照以下实例:[url]http://bbs.hexagonmetrology.com.cn/showtopic-15272.aspx[/url]
2015-12-19 12:05
景松刚
[b]回复 [url=http://bbs.hexagonmetrology.com.cn/showtopic.aspx?topicid=16669&postid=135702#135702]3楼[color=Olive]coord[/color]的帖子[/url][/b] 谢谢海风提供,学习了。
2015-12-19 16:34
谢谢海风 ,但这个不是我想要的,能不能给我看下代码,我主要看下XXZ是怎么导进pc-dmis的 我们许多客户会给我们测点的XYZIJK但是名字都是很没规则的 比如 U72200V123R,0051S 0052S 0053S这样软件没法根据规则向下命名 所有我想过给VBA能把测点名也导进程序,现在发现用CMD.id= cells(a,2)可以把名字改掉。但是XYZIJK怎么修改。 只是导入测点坐标还不如用.XYZ 文件来的方便
2015-12-20 08:56
