社区活动 技术论坛 高级编程应用-气电环规连续测量
高级编程应用-气电环规连续测量
2015-11-27 22:24 337 0 9
[attachimg]6087[/attachimg] [attachimg]6088[/attachimg] [font=微软雅黑]以上是气电环规小图片,由于其检测项目一样,类似于重复检测,在学习了高级编程之后,便想着是否可以将其应用出来,这是我的一点小想法,希望可以与大家一块分享![/font] [font=微软雅黑]在实现连续测量前,先要将环规编号及直径写入txt文件中,编号之间使用","作为分隔符;直径之间也使用","作为分隔符;编号、直径各占一行,并且一一对应[/font] [attachimg]6085[/attachimg] [font=微软雅黑][b]C3 =注释/输入,否,全屏=否,[/b][/font] [font=微软雅黑][b] '请输入被测工件的数目:'[/b][/font] [font=微软雅黑][b] 赋值/V=1[/b][/font] [font=微软雅黑][b]FPTR =文件/打开,F:\PC-DMIS\QT1505-070气电环规.txt,读取[/b][/font] [font=微软雅黑][b]V1 =文件/读取行,FPTR,{NUM1}+","+{NUM2}+","+{NUM3}+","+{NUM4}+","+{NUM5}+","+{NUM6}+","+{NUM7}[/b][/font] [font=微软雅黑][b]V2 =文件/读取行,FPTR,{DD1}+","+{DD2}+","+{DD3}+","+{DD4}+","+{DD5}+","+{DD6}+","+{DD7}[/b][/font] [font=微软雅黑][b] 文件/关闭,FPTR,保留[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM1[/b][/font] [font=微软雅黑][b] 赋值/DD=DD1[/b][/font] [font=微软雅黑][b]L1 =标号/[/b][/font] [font=微软雅黑]柱体1 =特征/柱体,直角坐标,内,最小二乘方[/font] [font=微软雅黑] 理论值/<390.962015,370.172295,-660.989179>,<-0.001006,-0.0007666,0.9999992>,12.004341,4.880386[/font] [font=微软雅黑] 实际值/<390.962015,370.172295,-660.989179>,<-0.001006,-0.0007666,0.9999992>,12.004341,4.880386[/font] [font=微软雅黑] 测定/柱体,8[/font] [font=微软雅黑] 触测/基本,常规,<396.946461,370.709402,-663.422942>,<-0.9960205,-0.0891185,-0.0010703>,<396.946461,370.709402,-663.422942>,使用理论值=是[/font] [font=微软雅黑] 移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<391.763[/font]347,376.120216,-663.423127>,<-0.1331579,-0.9910944,-0.0008938>,<391.763347,376.120216,-663.423127>,使用理论值=是 [font=微软雅黑]移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<385.011417,370.965992,-663.425442>,<0.991269,-0.1318518,0.0008961>,<385.011417,370.965992,-663.425442>,使用理论值=是[/font] [font=微软雅黑] 移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<391.22643,364.179625,-663.42296>,<-0.04366,0.9990462,0.000722>,<391.22643,364.179625,-663.42296>,使用理论值=是[/font] [font=微软雅黑] 移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<391.22628,364.178158,-658.553779>,<-0.0444666,0.9990106,0.0007212>,<391.22628,364.178158,-658.553779>,使用理论值=是[/font] [font=微软雅黑] 移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<396.937523,370.743544,-658.553256>,<-0.9954352,-0.0954333,-0.0010746>,<396.937523,370.743544,-658.553256>,使用理论值=是[/font] [font=微软雅黑] 移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<390.830165,376.166424,-658.55477>,<0.021577,-0.9997669,-0.0007448>,<390.830165,376.166424,-658.55477>,使用理论值=是[/font] [font=微软雅黑] 移动/圆弧[/font] [font=微软雅黑] 触测/基本,常规,<385.029692,371.119265,-658.554226>,<0.9874387,-0.1580005,0.0008722>,<385.029692,371.119265,-658.554226>,使用理论值=是[/font] [font=微软雅黑] 终止测量/[/font] [font=微软雅黑]A1 =坐标系/开始,回调:启动,列表=是[/font] [font=微软雅黑] 建坐标系/找平,Z正,柱体1[/font] [font=微软雅黑] 建坐标系/平移,X轴,柱体1[/font] [font=微软雅黑] 建坐标系/平移,Y轴,柱体1[/font] [font=微软雅黑] 坐标系/终止[/font] [font=微软雅黑]平面1 =特征/平面,直角坐标,三角形[/font] [font=微软雅黑] 理论值/<1.726627,0.500971,-655.750175>,<-0.0002959,0.0000341,1>[/font] [font=微软雅黑] 实际值/<1.726627,0.500971,-655.750175>,<-0.0002959,0.0000341,1>[/font] [font=微软雅黑] 测定/平面,3[/font] [font=微软雅黑] 触测/基本,常规,<13.95366,-0.953164,-655.746507>,<-0.0002959,0.0000341,1>,<13.95366,-0.953164,-655.746507>,使用理论值=是[/font] [font=微软雅黑] 触测/基本,常规,<-1.496033,10.723844,-655.751477>,<-0.0002959,0.0000341,1>,<-1.496033,10.723844,-655.751477>,使用理论值=是[/font] [font=微软雅黑] 触测/基本,常规,<-7.277747,-8.267767,-655.75254>,<-0.0002959,0.0000341,1>,<-7.277747,-8.267767,-655.75254>,使用理论值=是[/font] [font=微软雅黑] 终止测量/[/font] [font=微软雅黑]A2 =坐标系/开始,回调:A1,列表=是[/font] [font=微软雅黑] 建坐标系/平移,Z 轴,平面1[/font] [font=微软雅黑] 坐标系/终止[/font] [font=微软雅黑] 模式/自动[/font] [font=微软雅黑]柱体2 =特征/触测/柱体/默认,直角坐标,内,最小二乘方[/font] [font=微软雅黑] 理论值/<0,0,0>,<0,0,1>,[b]DD[/b],5[/font] [font=微软雅黑] 实际值/<0,0,0>,<0,0,1>,10.5183,5[/font] [font=微软雅黑] 目标值/<0,0,0>,<0,0,1>[/font] [font=微软雅黑] 起始角=0,终止角=360[/font] [font=微软雅黑] 角矢量=<0,1,0>[/font] [font=微软雅黑] 方向=逆时针[/font] [font=微软雅黑] 显示特征参数=否[/font] [font=微软雅黑] 显示相关参数=是[/font] [font=微软雅黑] 测点数=4,层数=2,深度=1.5,终止补偿=0,螺距=0[/font] [font=微软雅黑] 采样方法=SAMPLE_HITS[/font] [font=微软雅黑] 样例点=0,间隙=0[/font] [font=微软雅黑] 自动移动=两者,距离=15[/font] [font=微软雅黑] 查找孔=无效,出错=否,读位置=否[/font] [font=微软雅黑] 显示触测=否[/font] [font=微软雅黑]A3 =坐标系/开始,回调:A2,列表=是[/font] [font=微软雅黑] 建坐标系/找平,Z正,柱体2[/font] [font=微软雅黑] 建坐标系/平移,X轴,柱体2[/font] [font=微软雅黑] 建坐标系/平移,Y轴,柱体2[/font] [font=微软雅黑] 坐标系/终止[/font] [font=微软雅黑]平面2 =特征/触测/平面/默认,直角坐标,轮廓[/font] [font=微软雅黑] 理论值/<0,0,0>,<0,0,1>[/font] [font=微软雅黑] 实际值/<0,0,0>,<0,0,1>[/font] [font=微软雅黑] 目标值/<0,0,0>,<0,0,1>[/font] [font=微软雅黑] 角矢量=<0,1,0>,环形[/font] [font=微软雅黑] 显示特征参数=否[/font] [font=微软雅黑] 显示相关参数=是[/font] [font=微软雅黑] 测点数=4,行数=1[/font] [font=微软雅黑] 间隙=[b]DD[/b][/font] [font=微软雅黑] 自动移动=两者,距离=15[/font] [font=微软雅黑] 显示触测=否[/font] [font=微软雅黑]A4 =坐标系/开始,回调:A3,列表=是[/font] [font=微软雅黑] 建坐标系/平移,Z 轴,平面2[/font] [font=微软雅黑] 坐标系/终止[/font] [font=微软雅黑] [b]注释/报告,[/b][/font] [font=微软雅黑][b] NUM[/b][/font] [font=微软雅黑]DIM 位置1= 柱体 的位置柱体2 单位=毫米 ,$[/font] [font=微软雅黑]图示=关 文本=关 倍率=10.00 输出=两者 半角=否[/font] [font=微软雅黑]AX NOMINAL +TOL -TOL MEAS DEV OUTTOL[/font] [font=微软雅黑]直径 [b]DD[/b] 0.050000 -0.050000 10.518300 0.000000 0.000000 ----#----[/font] [font=微软雅黑]终止尺寸 位置1[/font] [font=微软雅黑] [b]赋值/V=V+1[/b][/font] [font=微软雅黑][b] IF_GOTO/V==C3.INPUT+1,转到 = END[/b][/font] [font=微软雅黑][b] 转到/"L"+V[/b][/font] [font=微软雅黑][b]L2 =标号/[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM2[/b][/font] [font=微软雅黑][b] 赋值/DD=DD2[/b][/font] [font=微软雅黑][b] 转到/L1[/b][/font] [font=微软雅黑][b]L3 =标号/[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM3[/b][/font] [font=微软雅黑][b] 赋值/DD=DD3[/b][/font] [font=微软雅黑][b] 转到/L1[/b][/font] [font=微软雅黑][b]L4 =标号/[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM4[/b][/font] [font=微软雅黑][b] 赋值/DD=DD4[/b][/font] [font=微软雅黑][b] 转到/L1[/b][/font] [font=微软雅黑][b]L5 =标号/[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM5[/b][/font] [font=微软雅黑][b] 赋值/DD=DD5[/b][/font] [font=微软雅黑][b] 转到/L1[/b][/font] [font=微软雅黑][b]L6 =标号/[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM6[/b][/font] [font=微软雅黑][b] 赋值/DD=DD6[/b][/font] [font=微软雅黑][b] 转到/L1[/b][/font] [font=微软雅黑][b]L7 =标号/[/b][/font] [font=微软雅黑][b] 赋值/NUM=NUM7[/b][/font] [font=微软雅黑][b] 赋值/DD=DD7[/b][/font] [font=微软雅黑][b] 转到/L1[/b][/font] [font=微软雅黑][b]END =标号/[/b][/font]
2015-11-27 22:24
想法很好,很直得学习:-D 高级编程还不会,只能看看,不过此类环规最好划线测量.深度取1/2H .小环规圆度可以控制,大环规研磨圆度就难保证了..毕竟气动量仪是两点测量的。
2015-11-27 23:29
[b]回复 [url=http://bbs.hexagonmetrology.com.cn/showtopic.aspx?topicid=16613&postid=135161#135161]2楼[color=Olive]JIAJI[/color]的帖子[/url][/b] 我们没试过划线测量,能把你们的方法详细说一下嘛?
2015-11-28 10:26
关注下跟学习。
2015-11-28 21:28
其实测量环规最好用测长仪比对测量比较好.三坐标是取平均值的,除非真圆度很好可以忽略.一般大坏规可以柱找正方向.直接测过圆心2点距离就行了,如果位了消除机器精度还可以用标准环规比对测量.以上所说只会为了更贴合实际保证测量准确性. 还有你的程序是否可以增加不同深度环规的测量,这样程序通用性更强.
2015-11-28 23:59
[b]回复 [url=http://bbs.hexagonmetrology.com.cn/showtopic.aspx?topicid=16613&postid=135186#135186]5楼[color=Olive]JIAJI[/color]的帖子[/url][/b] 可以,只需要在txt中添加深度就可以了,点之间的距离我们下次送检会主动对比一下,谢啦
2015-11-29 09:26
不客气!共同学习
2015-11-29 15:58
把你的高级编程资料分享下呗
2015-11-30 17:19
景松刚
关注 学习。
2015-12-02 19:06
