社区活动 技术论坛 关于外部坐标系
关于外部坐标系
2014-08-28 21:22 270 0 5
请教孙老师及各位同仁,请看下面程序 1.执行一次程序可循环测量3件摆放于不同位置与间距的相同零件尺寸 2.可分析测量数据状态判定是否需要重新测量,与自动列印测量报告 以下附测量程序: PART NAME : test REV NUMBER : SER NUMBER : STATS COUNT : 1 STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END MODE/DCC LOADPROBE/D120C20 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 ASSIGN/MEASURED_PARTNO = 0 INPUT_MODE =COMMENT/YESNO,是否需要手动确定零件位置? — (输入模式选择) ,"YES"==>>手动依次动建立1~3号零件粗定位坐标 ,"NO"==>>测量机将自动测量1~3号零件. IF/INPUT_MODE.INPUT=="YES" DO/ ASSIGN/MEASURED(精确的)_PARTNO = MEASURED_PARTNO+1 (初始值为1,依次增加至3) COMMENT/OPER,"请手动测量["+ MEASURED_PARTNO+"号]零件坐标!" MODE/MANUAL PLN1 =FEAT/PLANE,RECT THEO/111.216,52.835,0,0,0,1 ACTL/111.216,52.835,0,0,0,1 MEAS/PLANE,4 HIT/BASIC,47.162,95.095,0,0,0,1,47.162,95.095,0,USE THEO = YES HIT/BASIC,44.723,11.876,0,0,0,1,44.723,11.876,0,USE THEO = YES HIT/BASIC,164.813,10.472,0,0,0,1,164.813,10.472,0,USE THEO = YES HIT/BASIC,188.165,93.899,0,0,0,1,188.165,93.899,0,USE THEO = YES ENDMEAS/ LIN1 =FEAT/LINE,RECT,UNBND THEO/16.887,0,-6.103,1,0,0 ACTL/16.887,0,-6.103,1,0,0 MEAS/LINE,2,WORKPLANE HIT/BASIC,16.887,0,-6.103,0,-1,0,16.887,0,-6.103,USE THEO = YES HIT/BASIC,211.372,0,-5.865,0,-1,0,211.372,0,-5.865,USE THEO = YES ENDMEAS/ PNT1 =FEAT/POINT,RECT THEO/6.35,24.56,-5.632,-1,0,0 ACTL/6.35,24.56,-5.632,-1,0,0 MEAS/POINT,1 HIT/BASIC,6.35,24.56,-5.632,-1,0,0,6.35,24.56,-5.632,USE THEO = YES ENDMEAS/ A1 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS ALIGNMENT/TRANS,XAXIS,PNT1 ALIGNMENT/TRANS,YAXIS,LIN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/END SELECT/MEASURED_PARTNO CASE/1 SAVE/ALIGNMENT,A1,Part1_ali.aln,MACHINETOPARTS END_CASE/ CASE/2 SAVE/ALIGNMENT,A1,Part2_ali.aln,MACHINETOPARTS END_CASE/ CASE/3 SAVE/ALIGNMENT,A1,Part3_ali.aln,MACHINETOPARTS END_CASE/ END_SELECT/ UNTIL/MEASURED_PARTNO==3 (表达式比较真假 执行循环) END_IF (以上为手动粗建坐标系,根据需求依次测量3个工件) ASSIGN/MEASURED_PARTNO = 0 (重新赋值) DO/ ASSIGN /MEASURED_PARTNO = MEASURED_PARTNO+1 SELECT/MEASURED_PARTNO CASE/1 RECALL/ALIGNMENT,EXTERNAL,a1,PART1_ALI:a1 SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS END_CASE/ CASE/2 RECALL/ALIGNMENT,EXTERNAL,a1,PART2_ALI:a1 SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS END_CASE CASE/3 RECALL/ALIGNMENT,EXTERNAL,a1,PART3_ALI:a1 SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS (3次保存的坐标系文件名相同,被覆盖了) END_CASE/ END_SELECT/ MODE/DCC RECALL/ALIGNMENT,EXTERNAL,part_dccali,PART_DCCALI:part_dccali 此处回调的是什么坐标系? 我的理解为手动建立的3号工件坐标系位置,那这程序能运行3次吗?请各位指教
2014-08-28 21:22
程序不完整呀,第二个DO的until在哪里? 如果input第一次输入的是false,那下面的程序哪里找得到aln文件呢? 如果第一次输入的true,按程序读法,还是得看你的until在哪里。 请出示完整的程式。
2014-08-29 11:54
只是我到这一步发现程序可能运行不了或位置不对,下面上传整个程序其实下面就是精建坐标系和测量元素了请指教 1.执行一次程序可循环测量3件摆放于不同位置与间距的相同零件尺寸 2.可分析测量数据状态判定是否需要重新测量,与自动列印测量报告 以下附测量程序: PART NAME : test REV NUMBER : SER NUMBER : STATS COUNT : 1 STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END MODE/DCC LOADPROBE/D120C20 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 ASSIGN/MEASURED_PARTNO = 0 INPUT_MODE =COMMENT/YESNO,是否需要手动确定零件位置? — (输入模式选择) ,"YES"==>>手动依次动建立1~3号零件粗定位坐标 ,"NO"==>>测量机将自动测量1~3号零件. IF/INPUT_MODE.INPUT=="YES" DO/ ASSIGN/MEASURED(精确的)_PARTNO = MEASURED_PARTNO+1 (初始值为1,依次增加至3) COMMENT/OPER,"请手动测量["+ MEASURED_PARTNO+"号]零件坐标!" MODE/MANUAL PLN1 =FEAT/PLANE,RECT THEO/111.216,52.835,0,0,0,1 ACTL/111.216,52.835,0,0,0,1 MEAS/PLANE,4 HIT/BASIC,47.162,95.095,0,0,0,1,47.162,95.095,0,USE THEO = YES HIT/BASIC,44.723,11.876,0,0,0,1,44.723,11.876,0,USE THEO = YES HIT/BASIC,164.813,10.472,0,0,0,1,164.813,10.472,0,USE THEO = YES HIT/BASIC,188.165,93.899,0,0,0,1,188.165,93.899,0,USE THEO = YES ENDMEAS/ LIN1 =FEAT/LINE,RECT,UNBND THEO/16.887,0,-6.103,1,0,0 ACTL/16.887,0,-6.103,1,0,0 MEAS/LINE,2,WORKPLANE HIT/BASIC,16.887,0,-6.103,0,-1,0,16.887,0,-6.103,USE THEO = YES HIT/BASIC,211.372,0,-5.865,0,-1,0,211.372,0,-5.865,USE THEO = YES ENDMEAS/ PNT1 =FEAT/POINT,RECT THEO/6.35,24.56,-5.632,-1,0,0 ACTL/6.35,24.56,-5.632,-1,0,0 MEAS/POINT,1 HIT/BASIC,6.35,24.56,-5.632,-1,0,0,6.35,24.56,-5.632,USE THEO = YES ENDMEAS/ A1 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS ALIGNMENT/TRANS,XAXIS,PNT1 ALIGNMENT/TRANS,YAXIS,LIN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/END SELECT/MEASURED_PARTNO CASE/1 SAVE/ALIGNMENT,A1,Part1_ali.aln,MACHINETOPARTS END_CASE/ CASE/2 SAVE/ALIGNMENT,A1,Part2_ali.aln,MACHINETOPARTS END_CASE/ CASE/3 SAVE/ALIGNMENT,A1,Part3_ali.aln,MACHINETOPARTS END_CASE/ END_SELECT/ UNTIL/MEASURED_PARTNO==3 (表达式比较真假 执行循环) END_IF (以上为手动粗建坐标系,根据需求依次测量3个工件) ASSIGN/MEASURED_PARTNO = 0 (重新赋值) DO/ ASSIGN /MEASURED_PARTNO = MEASURED_PARTNO+1 SELECT/MEASURED_PARTNO CASE/1 RECALL/ALIGNMENT,EXTERNAL,a1,PART1_ALI:a1 SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS END_CASE/ CASE/2 RECALL/ALIGNMENT,EXTERNAL,a1,PART2_ALI:a1 SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS END_CASE/ CASE/3 RECALL/ALIGNMENT,EXTERNAL,a1,PART3_ALI:a1 SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS (以上标记红色部分坐标系文件名相同,被覆盖了) END_CASE/ END_SELECT/ MODE/DCC RECALL/ALIGNMENT,EXTERNAL,part_dccali,PART_DCCALI:part_dccali (此处回调的是手动建立的3号工件坐标系位置吗??) (以下为自动建立坐标系过程) CLEARP/ZPLUS,15,ZPLUS,0 PLN2 =FEAT/PLANE,RECT THEO/111.216,52.835,0,0,0,1 ACTL/111.216,52.835,0,0,0,1 MEAS/PLANE,4 MOVE/CLEARPLANE HIT/BASIC,47.162,95.095,0,0,0,1,47.162,95.095,0,USE THEO = YES HIT/BASIC,44.723,11.876,0,0,0,1,44.723,11.876,0,USE THEO = YES HIT/BASIC,164.813,10.472,0,0,0,1,164.813,10.472,0,USE THEO = YES HIT/BASIC,188.165,93.899,0,0,0,1,188.165,93.899,0,USE THEO = YES ENDMEAS/ LIN2 =FEAT/LINE,RECT,UNBND THEO/16.887,0,-6.103,1,0,0 ACTL/16.887,0,-6.103,1,0,0 MEAS/LINE,2,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,16.887,0,-6.103,0,-1,0,16.887,0,-6.103,USE THEO = YES HIT/BASIC,211.372,0,-5.865,0,-1,0,211.372,0,-5.865,USE THEO = YES ENDMEAS/ PNT2 =FEAT/POINT,RECT THEO/6.35,24.56,-5.632,-1,0,0 ACTL/6.35,24.56,-5.632,-1,0,0 MEAS/POINT,1 MOVE/CLEARPLANE HIT/BASIC,6.35,24.56,-5.632,-1,0,0,6.35,24.56,-5.632,USE THEO = YES ENDMEAS/ A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/LEVEL,ZPLUS,PLN2 ALIGNMENT/ROTATE,XPLUS,TO,LIN2,ABOUT,ZPLUS ALIGNMENT/TRANS,XAXIS,PNT2 ALIGNMENT/TRANS,YAXIS,LIN2 ALIGNMENT/TRANS,ZAXIS,PLN2 ALIGNMENT/END MOVE/CLEARPLANE CIR1 =AUTO/CIRCLE, SHOWALLPARAMS=NO, SHOWHITS=YES THEO/19.049,25.4,-3,0,0,1,25.4 ACTL/19.049,25.4,-3,0,0,1,25.4 TARG/19.049,25.4,-3,0,0,1 MEAS/CIRCLE HIT/BASIC,31.749,25.4,-3,-1,0,0,31.749,25.4,-3 HIT/BASIC,19.049,38.1,-3,0,-1,0,19.049,38.1,-3 HIT/BASIC,6.349,25.4,-3,1,0,0,6.349,25.4,-3 HIT/BASIC,19.049,12.7,-3,0,1,0,19.049,12.7,-3 ENDMEAS/ MOVE/CLEARPLANE CIR2 =AUTO/CIRCLE, SHOWALLPARAMS=NO, SHOWHITS=YES THEO/19.049,76.2,-3,0,0,1,25.4 ACTL/19.049,76.2,-3,0,0,1,25.4 TARG/19.049,76.2,-3,0,0,1 MEAS/CIRCLE HIT/BASIC,31.749,76.2,-3,-1,0,0,31.749,76.2,-3 HIT/BASIC,19.049,88.9,-3,0,-1,0,19.049,88.9,-3 HIT/BASIC,6.349,76.2,-3,1,0,0,6.349,76.2,-3 HIT/BASIC,19.049,63.5,-3,0,1,0,19.049,63.5,-3 ENDMEAS/ DIM LOC1= LOCATION OF CIRCLE CIR1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL X 19.049 0.000 0.000 19.049 31.749 6.349 0.000 0.000 ----#---- Y 25.400 0.000 0.000 25.400 38.100 12.700 0.000 0.000 ----#---- D 25.400 0.000 0.000 25.400 25.400 25.400 0.000 0.000 ----#---- END OF DIMENSION LOC1 DIMINFO/LOC1;DIMID,FEATID;HEADINGS,GRAPH AXIS;MEAS, , , , , , , , ,$ X,Y,D, , , , , , , , , , , , , , DIM LOC2= LOCATION OF CIRCLE CIR2 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL X 19.049 0.000 0.000 19.049 31.749 6.349 0.000 0.000 ----#---- Y 76.200 0.000 0.000 76.200 88.900 63.500 0.000 0.000 ----#---- D 25.400 0.000 0.000 25.400 25.400 25.400 0.000 0.000 ----#---- END OF DIMENSION LOC2 DIMINFO/LOC2;DIMID,FEATID;HEADINGS,GRAPH AXIS;MEAS, , , , , , , , ,$ X,Y,D, , , , , , , , , , , , , , ASSIGN/MEASURED_CIR1 = 0 ASSIGN/MEASURED_CIR2 = 0 ASSIGN/MEASURED_INFO = 0 ASSIGN/REPORT_BL = 0 IF/LOC1.X.OUTTOL<>0 OR LOC1.Y.OUTTOL<>0 OR LOC1.D.OUTTOL<>0 ASSIGN/MEASURED_CIR1 = 1 ASSIGN/MEASURED_INFO = "[CIR1]" END_IF/ IF/LOC2.X.OUTTOL<>0 OR LOC2.Y.OUTTOL<>0 OR LOC2.D.OUTTOL<>0 ASSIGN/MEASURED_CIR2 = 1 ASSIGN/MEASURED_INFO = MEASURED_INFO +"[CIR2]" END_IF/ IF/MEASURED_CIR1=1 OR MEASURED_CIR2=1 MEASURED_MODE =COMMENT/YESNO,"测量["+MEASURED_PARTNO+"号]零件发现:" ,“{” + MEASURED_INFO “}尺寸超差” ,“请选择是否重新测量[”+MEASURED_PARTNO+"号]零件" ,""YES"==>将重新测量" ,""NO"==>将列印此件报告并继续测量下一件零件" IF/MEASURED_MODE.INPUT=="YES" ASSIGN/MEASURED_PARTNO = MEASURED_PARTNO-1 END_IF/ ELSE/ ASSIGN/REPORT_BL = 1 END_ELSE/ END_IF/ ELSE/ ASSIGN/REPORT_BL = 1 END_ELSE/ IF/REPORT_BL==0 PRINT/REPORT,TO_FILE=ON,AUTO=1,$ TO_PRINTER=ON,DRAFTMODE=ON,$ PREVIOUS_RUNS=DELETE_INSTANCES END_IF/ UNTIL/MEASURED_PARTNO==3
2014-08-31 19:41
从你的程式来看,逻辑应该是没问题的;但pcdmis编辑窗口的程序语言逻辑,有点版本会有bug,不完全与计算机语言逻辑一致; 1,建立A2坐标系时,为什么回调的启动坐标系呢?不是回调的回调坐标系呢? 2,这么长的程式,又涉及到繁杂的计算机语言逻辑,最好是一步一步地作调试,不能急于求成地将代码全写好了再运行,这样出了问题也不知道是出在哪里;(就算写计算机程序也是一步一步地调试的,不是全写完了再调试)
2014-09-01 11:16
谢谢版主问题已解决
2014-09-03 19:54
