社区活动 技术论坛 PC-DMIS高级编程样例分享
PC-DMIS高级编程样例分享
2013-09-09 10:53 360 0 9
[color=rgb(255,0,0)][attach]3304[/attach][/color] [color=rgb(255,0,0)]样例程序功能:[/color] [color=rgb(255,0,0)]1.执行一次程序可循环测量3件摆放于不同位置与间距的相同零件尺寸[/color] [color=rgb(255,0,0)]2.可分析测量数据状态判定是否需要重新测量,与自动列印测量报告[/color] [color=rgb(255,0,0)][color=rgb(0,0,0)][size=24px][b]以下附测量程序:[/b][/size] PART NAME : test[/color] [color=rgb(0,0,0)][color=rgb(255,255,255)]REV NUMBER : [/color][/color] [color=rgb(0,0,0)]SER NUMBER : [/color] [color=rgb(0,0,0)]STATS COUNT : 1[/color] [color=rgb(0,0,0)]STARTUP =ALIGNMENT/START,RECALL:, LIST= YES[/color] [color=rgb(0,0,0)] ALIGNMENT/END[/color] [color=rgb(0,0,0)] MODE/DCC[/color] [color=rgb(0,0,0)] LOADPROBE/D120C20[/color] [color=rgb(0,0,0)] TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_PARTNO = 0[/color] [color=rgb(0,0,0)]INPUT_MODE =COMMENT/YESNO,是否需要手动确定零件位置?[/color] [color=rgb(0,0,0)] ,"YES"==>>手动依次动建立1~3号零件粗定位坐标[/color] [color=rgb(0,0,0)] ,"NO"==>>测量机将自动测量1~3号零件.[/color] [color=rgb(0,0,0)] IF/INPUT_MODE.INPUT=="YES"[/color] [color=rgb(0,0,0)] DO/[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_PARTNO = MEASURED_PARTNO+1[/color] [color=rgb(0,0,0)] COMMENT/OPER,"请手动测量["+ MEASURED_PARTNO+"号]零件坐标!"[/color] [color=rgb(0,0,0)] MODE/MANUAL[/color] [color=rgb(0,0,0)]PLN1 =FEAT/PLANE,RECT[/color] [color=rgb(0,0,0)] THEO/111.216,52.835,0,0,0,1[/color] [color=rgb(0,0,0)] ACTL/111.216,52.835,0,0,0,1[/color] [color=rgb(0,0,0)] MEAS/PLANE,4[/color] [color=rgb(0,0,0)] HIT/BASIC,47.162,95.095,0,0,0,1,47.162,95.095,0,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,44.723,11.876,0,0,0,1,44.723,11.876,0,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,164.813,10.472,0,0,0,1,164.813,10.472,0,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,188.165,93.899,0,0,0,1,188.165,93.899,0,USE THEO = YES[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]LIN1 =FEAT/LINE,RECT,UNBND[/color] [color=rgb(0,0,0)] THEO/16.887,0,-6.103,1,0,0[/color] [color=rgb(0,0,0)] ACTL/16.887,0,-6.103,1,0,0[/color] [color=rgb(0,0,0)] MEAS/LINE,2,WORKPLANE[/color] [color=rgb(0,0,0)] HIT/BASIC,16.887,0,-6.103,0,-1,0,16.887,0,-6.103,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,211.372,0,-5.865,0,-1,0,211.372,0,-5.865,USE THEO = YES[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]PNT1 =FEAT/POINT,RECT[/color] [color=rgb(0,0,0)] THEO/6.35,24.56,-5.632,-1,0,0[/color] [color=rgb(0,0,0)] ACTL/6.35,24.56,-5.632,-1,0,0[/color] [color=rgb(0,0,0)] MEAS/POINT,1[/color] [color=rgb(0,0,0)] HIT/BASIC,6.35,24.56,-5.632,-1,0,0,6.35,24.56,-5.632,USE THEO = YES[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]A1 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES[/color] [color=rgb(0,0,0)] ALIGNMENT/LEVEL,ZPLUS,PLN1[/color] [color=rgb(0,0,0)] ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS[/color] [color=rgb(0,0,0)] ALIGNMENT/TRANS,XAXIS,PNT1[/color] [color=rgb(0,0,0)] ALIGNMENT/TRANS,YAXIS,LIN1[/color] [color=rgb(0,0,0)] ALIGNMENT/TRANS,ZAXIS,PLN1[/color] [color=rgb(0,0,0)] ALIGNMENT/END[/color] [color=rgb(0,0,0)] SELECT/MEASURED_PARTNO[/color] [color=rgb(0,0,0)] CASE/1[/color] [color=rgb(0,0,0)] SAVE/ALIGNMENT,A1,Part1_ali.aln,MACHINETOPARTS[/color] [color=rgb(0,0,0)] END_CASE/[/color] [color=rgb(0,0,0)] CASE/2[/color] [color=rgb(0,0,0)] SAVE/ALIGNMENT,A1,Part2_ali.aln,MACHINETOPARTS[/color] [color=rgb(0,0,0)] END_CASE/[/color] [color=rgb(0,0,0)] CASE/3[/color] [color=rgb(0,0,0)] SAVE/ALIGNMENT,A1,Part3_ali.aln,MACHINETOPARTS[/color] [color=rgb(0,0,0)] END_CASE/[/color] [color=rgb(0,0,0)] END_SELECT/[/color] [color=rgb(0,0,0)] UNTIL/MEASURED_PARTNO==3[/color] [color=rgb(0,0,0)] END_IF/[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_PARTNO = 0[/color] [color=rgb(0,0,0)] DO/[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_PARTNO = MEASURED_PARTNO+1[/color] [color=rgb(0,0,0)] SELECT/MEASURED_PARTNO[/color] [color=rgb(0,0,0)] CASE/1[/color] [color=rgb(0,0,0)] RECALL/ALIGNMENT,EXTERNAL,a1,PART1_ALI:a1[/color] [color=rgb(0,0,0)] SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS[/color] [color=rgb(0,0,0)] END_CASE/[/color] [color=rgb(0,0,0)] CASE/2[/color] [color=rgb(0,0,0)] RECALL/ALIGNMENT,EXTERNAL,a1,PART2_ALI:a1[/color] [color=rgb(0,0,0)] SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS[/color] [color=rgb(0,0,0)] END_CASE/[/color] [color=rgb(0,0,0)] CASE/3[/color] [color=rgb(0,0,0)] RECALL/ALIGNMENT,EXTERNAL,a1,PART3_ALI:a1[/color] [color=rgb(0,0,0)] SAVE/ALIGNMENT,PART_DCCALI,Part_dccAli.aln,MACHINETOPARTS[/color] [color=rgb(0,0,0)] END_CASE/[/color] [color=rgb(0,0,0)] END_SELECT/[/color] [color=rgb(0,0,0)] MODE/DCC[/color] [color=rgb(0,0,0)] RECALL/ALIGNMENT,EXTERNAL,part_dccali,PART_DCCALI:part_dccali[/color] [color=rgb(0,0,0)] CLEARP/ZPLUS,15,ZPLUS,0[/color] [color=rgb(0,0,0)]PLN2 =FEAT/PLANE,RECT[/color] [color=rgb(0,0,0)] THEO/111.216,52.835,0,0,0,1[/color] [color=rgb(0,0,0)] ACTL/111.216,52.835,0,0,0,1[/color] [color=rgb(0,0,0)] MEAS/PLANE,4[/color] [color=rgb(0,0,0)] MOVE/CLEARPLANE[/color] [color=rgb(0,0,0)] HIT/BASIC,47.162,95.095,0,0,0,1,47.162,95.095,0,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,44.723,11.876,0,0,0,1,44.723,11.876,0,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,164.813,10.472,0,0,0,1,164.813,10.472,0,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,188.165,93.899,0,0,0,1,188.165,93.899,0,USE THEO = YES[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]LIN2 =FEAT/LINE,RECT,UNBND[/color] [color=rgb(0,0,0)] THEO/16.887,0,-6.103,1,0,0[/color] [color=rgb(0,0,0)] ACTL/16.887,0,-6.103,1,0,0[/color] [color=rgb(0,0,0)] MEAS/LINE,2,WORKPLANE[/color] [color=rgb(0,0,0)] MOVE/CLEARPLANE[/color] [color=rgb(0,0,0)] HIT/BASIC,16.887,0,-6.103,0,-1,0,16.887,0,-6.103,USE THEO = YES[/color] [color=rgb(0,0,0)] HIT/BASIC,211.372,0,-5.865,0,-1,0,211.372,0,-5.865,USE THEO = YES[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]PNT2 =FEAT/POINT,RECT[/color] [color=rgb(0,0,0)] THEO/6.35,24.56,-5.632,-1,0,0[/color] [color=rgb(0,0,0)] ACTL/6.35,24.56,-5.632,-1,0,0[/color] [color=rgb(0,0,0)] MEAS/POINT,1[/color] [color=rgb(0,0,0)] MOVE/CLEARPLANE[/color] [color=rgb(0,0,0)] HIT/BASIC,6.35,24.56,-5.632,-1,0,0,6.35,24.56,-5.632,USE THEO = YES[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES[/color] [color=rgb(0,0,0)] ALIGNMENT/LEVEL,ZPLUS,PLN2[/color] [color=rgb(0,0,0)] ALIGNMENT/ROTATE,XPLUS,TO,LIN2,ABOUT,ZPLUS[/color] [color=rgb(0,0,0)] ALIGNMENT/TRANS,XAXIS,PNT2[/color] [color=rgb(0,0,0)] ALIGNMENT/TRANS,YAXIS,LIN2[/color] [color=rgb(0,0,0)] ALIGNMENT/TRANS,ZAXIS,PLN2[/color] [color=rgb(0,0,0)] ALIGNMENT/END[/color] [color=rgb(0,0,0)] MOVE/CLEARPLANE[/color] [color=rgb(0,0,0)]CIR1 =AUTO/CIRCLE, SHOWALLPARAMS=NO, SHOWHITS=YES[/color] [color=rgb(0,0,0)] THEO/19.049,25.4,-3,0,0,1,25.4[/color] [color=rgb(0,0,0)] ACTL/19.049,25.4,-3,0,0,1,25.4[/color] [color=rgb(0,0,0)] TARG/19.049,25.4,-3,0,0,1[/color] [color=rgb(0,0,0)] MEAS/CIRCLE[/color] [color=rgb(0,0,0)] HIT/BASIC,31.749,25.4,-3,-1,0,0,31.749,25.4,-3[/color] [color=rgb(0,0,0)] HIT/BASIC,19.049,38.1,-3,0,-1,0,19.049,38.1,-3[/color] [color=rgb(0,0,0)] HIT/BASIC,6.349,25.4,-3,1,0,0,6.349,25.4,-3[/color] [color=rgb(0,0,0)] HIT/BASIC,19.049,12.7,-3,0,1,0,19.049,12.7,-3[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)] MOVE/CLEARPLANE[/color] [color=rgb(0,0,0)]CIR2 =AUTO/CIRCLE, SHOWALLPARAMS=NO, SHOWHITS=YES[/color] [color=rgb(0,0,0)] THEO/19.049,76.2,-3,0,0,1,25.4[/color] [color=rgb(0,0,0)] ACTL/19.049,76.2,-3,0,0,1,25.4[/color] [color=rgb(0,0,0)] TARG/19.049,76.2,-3,0,0,1[/color] [color=rgb(0,0,0)] MEAS/CIRCLE[/color] [color=rgb(0,0,0)] HIT/BASIC,31.749,76.2,-3,-1,0,0,31.749,76.2,-3[/color] [color=rgb(0,0,0)] HIT/BASIC,19.049,88.9,-3,0,-1,0,19.049,88.9,-3[/color] [color=rgb(0,0,0)] HIT/BASIC,6.349,76.2,-3,1,0,0,6.349,76.2,-3[/color] [color=rgb(0,0,0)] HIT/BASIC,19.049,63.5,-3,0,1,0,19.049,63.5,-3[/color] [color=rgb(0,0,0)] ENDMEAS/[/color] [color=rgb(0,0,0)]DIM LOC1= LOCATION OF CIRCLE CIR1 UNITS=MM ,$[/color] [color=rgb(0,0,0)]GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH[/color] [color=rgb(0,0,0)]AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL [/color] [color=rgb(0,0,0)]X 19.049 0.000 0.000 19.049 31.749 6.349 0.000 0.000 ----#----[/color] [color=rgb(0,0,0)]Y 25.400 0.000 0.000 25.400 38.100 12.700 0.000 0.000 ----#----[/color] [color=rgb(0,0,0)]D 25.400 0.000 0.000 25.400 25.400 25.400 0.000 0.000 ----#----[/color] [color=rgb(0,0,0)]END OF DIMENSION LOC1[/color] [color=rgb(0,0,0)] DIMINFO/LOC1;DIMID,FEATID;HEADINGS,GRAPH AXIS;MEAS, , , , , , , , ,$[/color] [color=rgb(0,0,0)] X,Y,D, , , , , , , , , , , , , , [/color] [color=rgb(0,0,0)]DIM LOC2= LOCATION OF CIRCLE CIR2 UNITS=MM ,$[/color] [color=rgb(0,0,0)]GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH[/color] [color=rgb(0,0,0)]AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL [/color] [color=rgb(0,0,0)]X 19.049 0.000 0.000 19.049 31.749 6.349 0.000 0.000 ----#----[/color] [color=rgb(0,0,0)]Y 76.200 0.000 0.000 76.200 88.900 63.500 0.000 0.000 ----#----[/color] [color=rgb(0,0,0)]D 25.400 0.000 0.000 25.400 25.400 25.400 0.000 0.000 ----#----[/color] [color=rgb(0,0,0)]END OF DIMENSION LOC2[/color] [color=rgb(0,0,0)] DIMINFO/LOC2;DIMID,FEATID;HEADINGS,GRAPH AXIS;MEAS, , , , , , , , ,$[/color] [color=rgb(0,0,0)] X,Y,D, , , , , , , , , , , , , , [/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_CIR1 = 0[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_CIR2 = 0[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_INFO = 0[/color] [color=rgb(0,0,0)] ASSIGN/REPORT_BL = 0[/color] [color=rgb(0,0,0)] IF/LOC1.X.OUTTOL<>0 OR LOC1.Y.OUTTOL<>0 OR LOC1.D.OUTTOL<>0[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_CIR1 = 1[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_INFO = "[CIR1]"[/color] [color=rgb(0,0,0)] END_IF/[/color] [color=rgb(0,0,0)] IF/LOC2.X.OUTTOL<>0 OR LOC2.Y.OUTTOL<>0 OR LOC2.D.OUTTOL<>0[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_CIR2 = 1[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_INFO = MEASURED_INFO +"[CIR2]"[/color] [color=rgb(0,0,0)] END_IF/[/color] [color=rgb(0,0,0)] IF/MEASURED_CIR1<>1 OR MEASURED_CIR2<>1[/color] [color=rgb(0,0,0)]MEASURED_MODE =COMMENT/YESNO,"测量["+MEASURED_PARTNO+"号]零件发现:"[/color] [color=rgb(0,0,0)] ,“{” + MEASURED_INFO “}尺寸超差”[/color] [color=rgb(0,0,0)] ,“请选择是否重新测量[”+MEASURED_PARTNO+"号]零件"[/color] [color=rgb(0,0,0)] ,""YES"==>将重新测量"[/color] [color=rgb(0,0,0)] ,""NO"==>将列印此件报告并继续测量下一件零件"[/color] [color=rgb(0,0,0)] IF/MEASURED_MODE.INPUT=="YES"[/color] [color=rgb(0,0,0)] ASSIGN/MEASURED_PARTNO = MEASURED_PARTNO-1[/color] [color=rgb(0,0,0)] END_IF/[/color] [color=rgb(0,0,0)] ELSE/[/color] [color=rgb(0,0,0)] ASSIGN/REPORT_BL = 1[/color] [color=rgb(0,0,0)] END_ELSE/[/color] [color=rgb(0,0,0)] END_IF/[/color] [color=rgb(0,0,0)] ELSE/[/color] [color=rgb(0,0,0)] ASSIGN/REPORT_BL = 1[/color] [color=rgb(0,0,0)] END_ELSE/[/color] [color=rgb(0,0,0)] IF/REPORT_BL==0[/color] [color=rgb(0,0,0)] PRINT/REPORT,TO_FILE=ON,AUTO=1,$[/color] [color=rgb(0,0,0)] TO_PRINTER=ON,DRAFTMODE=ON,$[/color] [color=rgb(0,0,0)] PREVIOUS_RUNS=DELETE_INSTANCES[/color] [color=rgb(0,0,0)] END_IF/[/color] [color=rgb(0,0,0)] UNTIL/MEASURED_PARTNO==3[/color] [/color]
2013-09-09 10:53
新手来学习了!
2013-09-09 12:42
支持下楼主的分享,顶一个。
2013-09-09 13:19
不错,学习下希望楼主多多发些这方面的资料
2013-09-09 18:39
支持下楼主的分享,顶一个。
2013-09-09 20:01
不错,支持一下。
2013-09-09 20:18
支持一下,不错不错。很好!!!
2013-09-09 21:02
鼓励创新,
2013-09-09 22:19
英文的看不懂啊,来个中文的就更好了。
2013-09-21 16:51
