社区活动 技术论坛 怎样用VB直接从特征提取测量值
怎样用VB直接从特征提取测量值
2013-01-10 19:43 103 0 8
各位大侠 怎样用VB直接从特征提取测量值?用哪个对象(FEATDATA,FEATCMD,COMMAND),具体的程式是怎样的?
给个范例给你看看。有兴趣的话研究一下,稍作修改便可作其它用途。 以下这个范例用于从PC-DMIS中读取测头直径: Sub Main() Dim App As Object Set App = CreateObject("PCDLRN.Application") Dim Part As Object Set Part = App.ActivePartProgram Dim MyProbes As Object Set MyProbes = Part.probes MyProbes.Visible = False Dim MyProbe As Object Set MyProbe = MyProbes.Item(1) Dim MyTips As Object Set MyTips = MyProbe.Tips Dim MyTip As Object Set MyTip = MyTips.Item(1) Dim MyDiam As Double MyDiam = MyTip.diam MsgBox (MyDiam) Set MyTip = Nothing Set MyTips = Nothing Set MyProbe = Nothing Set MyProbes = Nothing End Sub
2011-01-13 13:31
2013-01-10 19:43
谢谢! 以上明白 但怎样从特征导出形状公差值呢,例如:圆度, 下图的程度错在哪里? [attachimg]2695[/attachimg]
2013-01-29 21:28
[b]回复 [url=http://bbs.hexagonmetrology.com.cn/showtopic.aspx?topicid=12402&postid=96379#96379]3楼[color=Olive]ftdjcl[/color]的帖子[/url][/b] 24行是哪一行,你最好不要贴图 上文本
2014-03-07 14:08
Sub Main() Dim App As Object [color=DarkRed][color=Red] Set App = CreateObject("PCDLRN.Application")[/color] Dim Part As Object Set Part = App.ActivePartProgram Dim MyProbes As Object Set MyProbes = Part.probes MyProbes.Visible = False Dim MyProbe As Object Set MyProbe = MyProbes.Item(1) Dim MyTips As Object Set MyTips = MyProbe.Tips Dim MyTip As Object Set MyTip = MyTips.Item(1) Dim MyDiam As Double MyDiam = MyTip.diam MsgBox (MyDiam) Set MyTip = Nothing Set MyTips = Nothing Set MyProbe = Nothing Set MyProbes = Nothing End Sub
2014-03-07 16:19
不行啊
2014-03-07 16:20
也很期待,如何能把测好的报告中的测量值导出来,按编号顺序的导出来,且只导测量值,其它的数据不导出来。 这样就很方便做报告了。DATAPAGE 是可以的,但也很麻烦,还是收费的。
2014-03-10 16:28
Set App = CreateObject("PCDLRN.Application")这句在我Excel里面为什么错误
2018-03-31 17:41
