社区活动 技术论坛 代码有点问题,谁来帮我优化一下
代码有点问题,谁来帮我优化一下
2011-05-03 08:36 243 0 10
我的想法是做3个同心圆。附件后缀改成doc就可以了。 [font=宋体]移动[/font][font=Times New Roman]/[/font][font=宋体]安全平面[/font] [font=Times New Roman] [/font][font=宋体]赋值[/font][font=Times New Roman]/V1=V73[/font] [font=Times New Roman] [/font][font=宋体]赋值[/font][font=Times New Roman]/V2=180[/font] [font=Times New Roman] [/font][font=宋体]赋值[/font][font=Times New Roman]/V4=18[/font] [font=Times New Roman] [/font][font=宋体]赋值[/font][font=Times New Roman]/V5=0[/font] [font=Times New Roman] DO/[/font] [font=Times New Roman]P4=[/font][font=宋体]特征[/font][font=Times New Roman]/[/font][font=宋体]接触[/font][font=Times New Roman]/[/font][font=宋体]矢量点[/font][font=Times New Roman],[/font][font=宋体]极坐标[/font] [font=Times New Roman] [/font][font=宋体]理论值[/font][font=Times New Roman]/<V1,V2,0.001>,<0.0001926,0.0001626,1>[/font] [font=Times New Roman] [/font][font=宋体]实际值[/font][font=Times New Roman]/<52.517,53.942,0.19>,<0.0001926,0.0001626,1>[/font] [font=宋体] 目标值[/font][font=Times New Roman]/<V1,V2,0.001>,<0.0001926,0.0001626,1>[/font] [font=Times New Roman] SNAP=[/font][font=宋体]否[/font] [font=Times New Roman] [/font][font=宋体]显示特征参数[/font][font=Times New Roman]=[/font][font=宋体]否[/font] [font=Times New Roman] [/font][font=宋体]显示相关参数[/font][font=Times New Roman]=[/font][font=宋体]是[/font] [font=Times New Roman] [/font][font=宋体]自动移动[/font][font=Times New Roman]=[/font][font=宋体]否[/font][font=Times New Roman],[/font][font=宋体]距离[/font][font=Times New Roman]=0[/font] [font=Times New Roman] [/font][font=宋体]显示触测[/font][font=Times New Roman]=[/font][font=宋体]否[/font] [font=Times New Roman] [/font][font=宋体]移动[/font][font=Times New Roman]/[/font][font=宋体]圆弧[/font] [font=Times New Roman][/font] [font=Times New Roman] IF/V1==V73[/font] [font=Times New Roman] [/font][font=宋体]赋值[/font][font=Times New Roman]/V2=V2-18[/font] [font=Times New Roman] IF/V2<=0.00001[/font] [font=宋体][font=Times New Roman] [/font]赋值[/font][font=Times New Roman]/V1=V1+3[/font] [font=Times New Roman] END_IF/[/font][font=Times New Roman] END_IF/[/font][font=Times New Roman] ELSE_IF/V1==V73+3[/font] [font=宋体][font=Times New Roman] [/font]赋值[/font][font=Times New Roman]/V2=V2+18[/font][font=Times New Roman] IF/V2>=180+0.00001[/font] [font=宋体][font=Times New Roman] [/font]赋值[/font][font=Times New Roman]/V1=V1+3[/font][font=Times New Roman] END_IF/[/font][font=Times New Roman] END_ELSEIF/[/font][font=Times New Roman] ELSE_IF/V1==V73+6[/font] [font=宋体][font=Times New Roman] [/font]赋值[/font][font=Times New Roman]/V2=V2-18[/font][font=Times New Roman] IF/V2<=0.00001[/font] [font=宋体][font=Times New Roman] [/font]赋值[/font][font=Times New Roman]/V1=V1+3[/font] [font=Times New Roman] END_IF/[/font] [font=Times New Roman] END_ELSEIF/[/font] [font=宋体][font=Times New Roman] [/font]赋值[/font][font=Times New Roman]/V5=V5+1[/font][font=Times New Roman] UNTIL/V5==30[/font] [font=宋体][font=Times New Roman] [/font]移动[/font][font=Times New Roman]/[/font][font=宋体]安全平面[/font] [font=宋体][/font] [font=宋体][/font] [font=Times New Roman][/font]
2011-05-03 08:36
没看你的附件,单看你的帖子代码,觉得你的代码不全吧? “赋值/V1=V73”是一个变量,那么V73的值是什么呢?如果第一次执行时,没有给代码V73赋值,那么它应该是为零吧?第一次触测点的X坐标为零吗?
2011-05-03 10:41
v73在程序开始赋值,对这段代码基本没有影响。
2011-05-04 09:46
其实我对楼主的代码完全不明白,初始赋值V1=V73了,在循环中的第一个IF/END IF块中,条件为当V1=V73,这个条件不是会成立10次吗?所以单看这段程序,头10个点应该是X坐标不变,Y坐标的点间距为18的直线排列的点,请问是怎样能测量得圆的呢? 再说了测3个同心圆,需要搞这么复杂吗? 你不如直接用圆命令,X,Y值可定值,当然也可为你要的变量,圆直径为变量,重复3次,不就可以了? 求高手解释楼主这段代码!
2011-05-04 11:06
我不会测量平行z轴的平面,测针只能用00角度,不愿意用操作杆点来点去。你教教我,好不?这段代码的目的就是测量一个垂直台面的平面。 谢谢。 每10个点在一个半径的园上,测完这10个,半径加3再测10个,再加3. 可实际情况是两头两位有了偏差,明显的上面那些if出了问题。我又想不出另外的方法。
2011-05-05 09:06
给你一个例子代码,不知道能否帮到你: ------------------------------------------------------------- MODE/DCC CLEARP/ZPLUS,30,ZPLUS,0,ON C1 =COMMENT/INPUT,NO,'输入圆直径!' ASSIGN/V1 = C1.INPUT ASSIGN/V2 = -15 ASSIGN/V3 = 1 DO/ MOVE/CIRCULAR CIR1 =FEAT/CONTACT/CIRCLE,CARTESIAN,IN,LEAST_SQR THEO/<124,50,V2>,<0,0,1>,V1,90,270 ACTL/<124,50,5>,<0,0,1>,56,90,270 TARG/<124,50,V2>,<0,0,1> ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW ADVANCED MEASUREMENT OPTIONS=NO SHOW_CONTACT_PARAMETERS=YES NUMHITS=10,DEPTH=3,PITCH=0 SAMPLE HITS=0,SPACER=2 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOWHITS=NO ASSIGN/V1 = V1+6 ASSIGN/V2 = V2+10 ASSIGN/V3 = V3+1 MOVE/CLEARPLANE UNTIL/V3>3 ----------------------------------------------------------------------------- 顺便上图,敬请楼主注意,以后如果有解决的问题时,尽量上图,才能得到完美解决! [attachimg]1578[/attachimg] [attachimg]1579[/attachimg]
2011-05-05 11:50
附件里有图呀, 这个圆平行与台面吧?我需要测量的圆是垂直台面的。测针还不能转角度。只能用a0b0.
2011-05-05 15:33
看程序和图吧,其实只是把圆的矢量方向改一下就好了: -------------------------------------------------------- LOADPROBE/L67-5D1 [color=blue]TIP/T1A0B0[/color], SHANKIJK=0, 0, 1, ANGLE=0 MODE/DCC CLEARP/ZPLUS,120,ZPLUS,0,ON ASSIGN/V1 = 40 ASSIGN/V2 = 60 ASSIGN/V3 = 1 DO/ CIR1 =FEAT/CONTACT/CIRCLE,CARTESIAN,IN,LEAST_SQR THEO/<50,V2,100>,<0,-1,0>,V1,180,360 ACTL/<50,20,100>,<0,-1,0>,80,180,360 TARG/<50,V2,100>,<0,-1,0> ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW ADVANCED MEASUREMENT OPTIONS=NO SHOW_CONTACT_PARAMETERS=YES NUMHITS=10,DEPTH=3,PITCH=0 SAMPLE HITS=0,SPACER=2 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOWHITS=NO ASSIGN/V1 = V1+20 ASSIGN/V2 = V2-20 ASSIGN/V3 = V3+1 MOVE/CLEARPLANE UNTIL/V3>3 ------------------------------------------------------------------------------------------------- [attachimg]1581[/attachimg] 下次请把你要解决的问题整理后表达清楚,不要一个问题要几次才能表达完整,记住,搞测量是要有很严谨的逻辑思维的,要不然你测的数据哪里有保障?如果你的最初思维不严谨,会造成数据不准确,当别人根据你的测量数据改模时,不是会改个稀巴烂?
2011-05-06 08:42
您教训的极是,在下谢谢了。 还要麻烦您, 我想测量您下面模型当中的xz面,怎么测量?
2011-05-06 09:21
谁来帮我看看
2011-05-09 23:07
