社区活动 技术论坛 请教VB中的combo下拉框在pcdmis中的运用!
2011-04-28 09:17 89 0 9
如下图中,如何[color=red]让VB开发出来的小程序中的combo下拉框获得pcdmis编辑窗口中的元素[/color]呢?望大侠们不吝赐教! [attachimg]1570[/attachimg]
2011-04-28 09:17
吼吼吼! 刚把问题提出来,自己就搞出来了,原来要循环才可以的!代码贴出: ------------------------------------------------------------------------- Dim App1 As Object Dim part As Object Dim Cmds As Object Dim cmd As Object Private Sub Form_Load() Set App1 = CreateObject("PCDLRN.Application") Set part = App1.ActivePartProgram Set Cmds = part.Commands For Each cmd In Cmds Combo1.AddItem cmd Next cmd End Sub ---------------------------------------------------------------------------- [color=red]但是不太理想,把启动和测尖不相关的命令全拉进来的,现在还请教大虾们,如果我只要点命令显示出来,如何搞?[/color] [attachimg]1571[/attachimg]
2011-04-28 09:32
to 2楼:在循环中需要判断命令是不是特征,加上这句 If Cmd.IsFeature Then 就可以判断出来是特征了,但是判断点我也不知道啊。 看来还是要学习
2011-04-28 10:02
哦,原来楼主和2楼是一个人,囧
2011-04-28 10:02
加一段错误处理代码: -------------------------------------------- Dim App1 As Object Dim part As Object Dim Cmds As Object Dim cmd As Object Private Sub Form_Load() On Error GoTo aaq: Set App1 = CreateObject("PCDLRN.Application") Set part = App1.ActivePartProgram Set Cmds = part.Commands Combo1.Text = "请选择元素" For Each cmd In Cmds Combo1.AddItem cmd Next cmd Exit Sub aaq: MsgBox "只能在pcdmis零件打开时使用本工具!", vbOKOnly, "温馨提示": Unload Me End Sub ---------------------------------------------------
2011-04-28 10:13
[quote] 原帖由 [b]smallpig[/b] 于 2011-4-28 10:02:00 发表 to 2楼:在循环中需要判断命令是不是特征,加上这句 If Cmd.IsFeature Then 就可以判断出来是特征了,但是判断点我也不知道啊。 看来还是要学习 [/quote]感谢啊,呵呵! ---------------------------------------------------- Dim App1 As Object Dim part As Object Dim Cmds As Object Dim cmd As Object Private Sub Form_Load() On Error GoTo aaq: Set App1 = CreateObject("PCDLRN.Application") Set part = App1.ActivePartProgram Set Cmds = part.Commands Combo1.Text = "请选择元素" For Each cmd In Cmds If cmd.IsFeature Then Combo1.AddItem cmd End If Next cmd Exit Sub aaq: MsgBox "只能在pcdmis零件打开时使用本工具!", vbOKOnly, "温馨提示": Unload Me End Sub -------------------------------------------------------- [attachimg]1572[/attachimg]
2011-04-28 10:15
有兴趣的可以参看《实用坐标测量技术》P50,有一个例子。
2011-04-28 12:33
我来看看P50
2011-04-28 23:07
楼上,看出来了吗?
2011-04-29 09:43
