社区活动 技术论坛 测量机错误!求助
测量机错误!求助
2009-03-08 20:02 345 0 4
TR_FG118,Z Amplitude Error 紧急错误 3.8 无法开机,终端显示的错误,最后一句是机子重新启动后的错误提示 System Status ------------------------------------------ Error Status : Jogbox Fault Feedhold Status : Use Jogbox Rate Sloop_Status : in_estop Fgrnd_Status : sloop_in_estop Wrist Status : ph9_ok_manual Autzer_Done : FALSE Probe_Type : pr_ren Probe_Seated : TRUE 廝廢ERROR LTC86 ,S%0 ,TR_INIT , COM-CTL V19.00 XCEL SCAN TR_FG032 Jogbox Fault 回零时出现的错误 System Status ------------------------------------------ Error Status : JogKeybdFailure Feedhold Status : Use Jogbox Rate Sloop_Status : in_estop Fgrnd_Status : sloop_in_estop Wrist Status : ph9_ok_manual Autzer_Done : FALSE Probe_Type : pr_ren Probe_Seated : TRUE 开机后终端显示的错误 ERROR LTC86 ,S%2 ,TR_EXE00,invalid Command 在使用中断电打开终端的错误 System Status ------------------------------------------ Error Status : Jogbox Fault Feedhold Status : Use Jogbox Rate Sloop_Status : in_estop Fgrnd_Status : sloop_in_estop Wrist Status : ph9_ok_manual Autzer_Done : TRUE Probe_Type : pr_ren Probe_Seated : TRUE 换操纵盒后在测量时出现的错误 System Status ------------------------------------------ Error Status : Z_AmplitudeError Feedhold Status : Use Jogbox Rate Sloop_Status : in_estop Fgrnd_Status : sloop_in_estop Wrist Status : ph9_ok_manual Autzer_Done : TRUE Probe_Type : pr_ren Probe_Seated : TRUE 会是怎么回事呢 ?
2009-03-08 20:02
错误来自操纵盒,具体是什么? 是Z轴旋转处出错,你再更换部件试试。
2009-03-08 21:15
hehhe 到超级终端可以解决 海的工程师知道 看他们告诉你不 test soft
2009-03-24 23:28
是Z轴的细分块坏了,已经更换.
2009-03-28 09:39
