社区活动 技术论坛 For CMM Data Import -Finally originalwork self-use sharing
2009-01-08 09:05 236 0 3
Contain Three part content. 1. Import data's command button, arrange them according to the format of CMM Data report. Note: It can be used in PC-Dmis 3.7 normally which is using by us. I modify some detail to change the dispaly style and to use it conveniently. 2.Increase a little work by which you can reuse this program. Note: Only need you click the "0. Clean All" button to get this function. 3.Increase a little work by which you can get the FAI report style's data, you can see it in Sheet "Transfer". Thanks for you using. -->For CMM Data Import -Finally originalwork self-use sharing If you have anyquestion, write Some Messages,let Me know you have come here! 程序包括三部分 1.导入数据按钮,能够按照测量机报告格式在Excel中组织数据; PC-Dmis 3.7中验证正常。 2.点击"0. Clean All" 按钮,能够反复使用同一提取程序进行数据提取; 3.在表单"Transfer"中可生成FAI报告样式的数据列表。 程序中三个按键"0. Clean All" - 清除所有 "1. Import Datal" - 导入数据 "2. Rearrange" - 格式调整 程序系个人自用整理的。谢谢使用,有问题请留言。
所有回贴(3)
2009-01-08 09:05
If you wrote in Chinese, everyone should read it easy.
2009-01-08 10:21
:D Chinese
2009-01-08 14:16
