社区活动 技术论坛 TP200的寿命
TP200的寿命
2008-10-30 09:29 95 0 4
一个TP200撞了多少次才会坏;我们公司有的TP200撞了好多次还没坏,是不是哪天谁倒霉轻轻一碰就坏了;哪不是很亏。TP200也有没有校正期限
2008-10-30 09:29
Excellent repeatability and precision 3D form measurement  Rapid exchange between stylus configurations without the need to re-calibrate  6 way measuring capability (±X, ±Y, ±Z)  SF and LF modules to give overtravel force to suit the application  EO module to give increased overtravel in probe Z axis  Zero reseat errors and no lobing effect  Suitable for intensive ‘peck’ or ‘stitch’ scanning  Stylus reach up to 100 mm (3.99 in) GF range  Module life of >10 million triggers  Compact size  Compatible with the full range of Renishaw probe heads and accessories
2008-10-30 10:36
一般如果你撞它的话,那就真不知道什么时候坏了! 正常使用下寿命应该>10,000,000次的触发
2008-10-30 10:39
海克斯康的维修工程师说使用寿命为100万次,我们公司的TP200可能触发了300万次以上了,仍然在顽强地工作。
2008-11-01 14:06
