社区活动 技术论坛 如何将扫描得到的理论xyz和测量值xyz读出来?
2008-02-28 09:55 155 0 12
SCN1 =特征/扫描,开放路径,显示触测=是,显示所有参数=否 测定/扫描 基本扫描/直线,显示触测=是,显示所有参数=否 触测/矢量,2760.108,-622.292,655.257,-0.2155716,0.9379919,-0.2714777,2760.108,-622.292,655.257,T=0 触测/矢量,2758.751,-623.186,653.322,-0.2280746,0.9319793,-0.281774,2758.751,-623.186,653.322,T=0 触测/矢量,2757.398,-624.126,651.389,-0.2416659,0.9250057,-0.293193,2757.398,-624.126,651.389,T=0 触测/矢量,2756.056,-625.112,649.471,-0.2564415,0.9169879,-0.3055667,2756.056,-625.112,649.471,T=0 触测/矢量,2745.973,-635.081,634.974,-0.4235232,0.7975459,-0.4295912,2745.973,-635.081,634.974,T=0 触测/矢量,2744.833,-636.637,633.321,-0.4494654,0.7733767,-0.4470674,2744.833,-636.637,633.321,T=0 触测/矢量,2743.731,-638.27,631.717,-0.476239,0.7464603,-0.4647509,2743.731,-638.27,631.717,T=0 触测/矢量,2742.67,-639.983,630.17,-0.5040664,0.7160254,-0.4829335,2742.67,-639.983,630.17,T=0 触测/矢量,2741.656,-641.778,628.686,-0.5327146,0.6817567,-0.5014209,2741.656,-641.778,628.686,T=0 触测/矢量,2740.699,-643.658,627.271,-0.5618435,0.6434475,-0.5199107,2740.699,-643.658,627.271,T=0 触测/矢量,2739.799,-645.623,625.94,-0.5910069,0.6010548,-0.538,2739.799,-645.623,625.94,T=0 触测/矢量,2738.963,-647.673,624.696,-0.619485,0.5550586,-0.555111,2738.963,-647.673,624.696,T=0 触测/矢量,2738.198,-649.805,623.549,-0.6468949,0.5053289,-0.5711127,2738.198,-649.805,623.549,T=0 触测/矢量,2737.509,-652.015,622.506,-0.6728193,0.4517522,-0.5858619,2737.509,-652.015,622.506,T=0 触测/矢量,2736.903,-654.298,621.576,-0.6966919,0.3946204,-0.5990786,2736.903,-654.298,621.576,T=0 触测/矢量,2736.446,-656.332,620.866,-0.7149606,0.3439043,-0.6087373,2736.446,-656.332,620.866,T=0 终止扫描 终止测量/
2008-02-28 09:55
文件--导出--Generic,选择导出的路径,输入文件名,点确定,选择坐标系,点确定 导出后的就是每个扫描的质心点和每一个触测点的坐标值和矢量
2008-02-28 10:22
2楼的方式我用过,谢谢! 可否利用表达式或变量的方式输出?謝謝! 可否贴上来看看。
2008-02-28 10:32
SCN1.hits[1].txyz为理论值,SCN1.hits[1].xyz为实测值,用循环取值,以此类推
2008-02-28 13:10
delphi 你好 可否写完整? 正在学习中! 谢谢!
2008-02-28 17:51
试试这个 [attachimg]40szb@257540955036.jpg[/attachimg]
2008-02-28 19:09
选择文件导出--.TXT格式就可以了!
2008-02-28 19:20
楼上的方法简单,导出的结果没有理论数据 平常用这个做 [attachimg]40szb@257543021065.jpg[/attachimg]
2008-02-28 19:44
呵呵 也可以!不过机器比较辛苦! 特征的点数可以用函数:SCN1.NUMHITS。
2008-02-28 20:21
SCN1 =FEAT/SCAN,LINEAROPEN,SHOWHITS=NO,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,SHOWHITS=NO,SHOWALLPARAMS=NO ENDSCAN ENDMEAS/ ASSIGN/NUM = 1 FPTR =FILE/OPEN,F:\SCAN.TXT,WRITE WHILE/NUM<=SCN1.NUMHITS FILE/WRITELINE,FPTR,SCN1.HIT[NUM].TX+","+SCN1.HIT[NUM].TY+","+SCN1.HIT[NUM].TZ+","+SCN1.HIT[NUM].TI+","+SCN1.HIT[NUM].TJ+","+SCN1.HIT[NUM].TK+","+SCN1.HIT[NUM].X+","+SCN1.HIT[NUM].Y+","+SCN1.HIT[NUM].Z ASSIGN/NUM = NUM+1 END_WHILE/ FILE/CLOSE,FPTR,KEEP 文件中的点格式为:TX,TY,TZ,TI,TJ,TK,X,Y,Z SCN1 =FEAT/SCAN,LINEAROPEN,SHOWHITS=NO,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,SHOWHITS=NO,SHOWALLPARAMS=NO ENDSCAN ENDMEAS/ ASSIGN/NUM = 1 FPTR =FILE/OPEN,F:\SCAN.TXT,WRITE WHILE/NUM<=SCN1.NUMHITS FILE/WRITELINE,FPTR,SCN1.HIT[NUM].TXYZ+","+SCN1.HIT[NUM].TIJK+","+SCN1.HIT[NUM].XYZ ASSIGN/NUM = NUM+1 END_WHILE/ FILE/CLOSE,FPTR,KEEP 文件中的点格式为:,, TX,TY,TZ,TI,TJ,TK,TXYZ,TIJK:理论值 X,Y,Z,I,J,K,XYZ,IJK:实测值
2008-02-28 22:06
