社区活动 技术论坛 关于保存多张视图报告的解决方法。
关于保存多张视图报告的解决方法。
2006-11-14 13:02 196 0 25
由于我们公司的报告格式是以视图的方式进行保存,可一个复杂的零件往往需要保存两张、三张甚至更多的视图,在实际使用中我们遇到了存第二幅视图后就不能看到第一幅视图,依此类推,一个复杂的零件程序假如需要保存3张视图,结果就只能看到一张。到下次使用该程序时又得重新评价和保存。但这种情况不是所有的程序都是这样,偶尔有一两个程序还是可以顺利保存两张以上的视图,操作步骤都是一样的。很奇怪,望大家以及管理员指点。谢谢! 2楼是该问题的图片                   [此贴子已经被作者于2006-11-14 13:04:43编辑过]                [此贴子已经被 admin 于2006-12-28 13:19:22编辑过]
所有回贴(25)
2006-11-14 13:02
以下附件是1楼问题的图片和步骤 [IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
2006-11-14 13:12
PART NAME : B6-LENS-L REV NUMBER : SER NUMBER : STATS COUNT : 1 STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END MODE/MANUAL LOADPROBE/TEST TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 FORMAT/TEXT,OPTIONS,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,DEV, , , RPSX1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-857.906,-490,363,-0.8677011,-0.4308516,0.2479146 ACTL/40.321,252.919,-556.442,-0.225491,-0.0262071,0.9738927 TARG/-857.906,-490,363,-0.8677011,-0.4308516,0.2479146 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 TIP/T1A90B-90, SHANKIJK=1, 0, 0, ANGLE=-90 RPSX2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-510.611,-772.173,456.696,0.9625368,0,-0.2711512 ACTL/475.176,382.214,-613.201,0.6196302,-0.0354188,-0.7840943 TARG/-510.611,-772.173,456.696,0.9625368,0,-0.2711512 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 RPSX3 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-538.765,-785.024,390.235,0.9171757,-0.0180034,0.3980762 ACTL/470.56,311.228,-601.531,0.5785811,0.5949752,-0.5578964 TARG/-538.765,-785.024,390.235,0.9171757,-0.0180034,0.3980762 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 TIP/T1A60B180, SHANKIJK=0, -0.866, 0.5, ANGLE=180 RPSZ1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-631,-743,367.101,-0.0189987,-0.1829873,-0.9829317 ACTL/379.16,273.112,-564.266,0.168094,-0.9758256,-0.1396739 TARG/-631,-743,367.101,-0.0189987,-0.1829873,-0.9829317 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 RPSZ2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-851,-490,343.963,-0.0519831,-0.076975,-0.995677 ACTL/45.164,235.855,-565.82,0.0657344,-0.9806768,-0.1842609 TARG/-851,-490,343.963,-0.0519831,-0.076975,-0.995677 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 TIP/T1A30B0, SHANKIJK=0, 0.5, 0.866, ANGLE=0 RPSY1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-531.5,-783,426,-0.2870135,-0.9110428,0.2960139 ACTL/471.118,346.573,-598.06,0.5113997,0.0874728,0.8548794 TARG/-531.5,-783,426,-0.2870135,-0.9110428,0.2960139 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 A1 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/ITERATE PNT TARGET RAD = 5, START LABEL = , FIXTURE TOL = 0.05, ERROR LABEL = MEAS ALL FEAT = ONCE ,LEVEL AXIS=XAXIS ,ROTATE AXIS=ZAXIS ,ORIGIN AXIS=YAXIS LEVEL = RPSX1,RPSX2,RPSX3,, ROTATE = RPSZ1,RPSZ2,, ORIGIN = RPSY1,, ALIGNMENT/END MODE/DCC PREHIT/ 3 RETRACT/ 3 MOVE/POINT,-624.134,-851.531,476.952 MOVE/POINT,-939.525,-534.647,411.708 TIP/T1A0B0, SHANKIJK=-0.763, -0.533, 0.366, ANGLE=-71.448 RPSX1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-857.906,-490,363,-0.8677011,-0.4308516,0.2479146 ACTL/-857.898,-490.001,362.996,-0.8677011,-0.4308516,0.2479146 TARG/-857.906,-490,363,-0.8677011,-0.4308516,0.2479146 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 PC2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-804.28,-510,449,-0.7261615,-0.358107,0.5868976 ACTL/-803.702,-509.715,448.532,-0.7261615,-0.358107,0.5868976 TARG/-804.28,-510,449,-0.7261615,-0.358107,0.5868976 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 MOVE/POINT,-630.886,-825.657,528.988 PC6 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-535.63,-770,454,-0.3490373,-0.832089,0.4310461 ACTL/-535.566,-769.847,453.921,-0.3490373,-0.832089,0.4310461 TARG/-535.63,-770,454,-0.3490373,-0.832089,0.4310461 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 RPSY1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-531.5,-783,426,-0.2870135,-0.9110428,0.2960139 ACTL/-531.482,-782.965,425.987,-0.2870135,-0.9110428,0.2960139 TARG/-531.5,-783,426,-0.2870135,-0.9110428,0.2960139 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 PC7 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-564.8,-783,385,-0.3520979,-0.9082525,0.2260629 ACTL/-564.869,-783.178,385.044,-0.3520979,-0.9082525,0.2260629 TARG/-564.8,-783,385,-0.3520979,-0.9082525,0.2260629 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 MOVE/POINT,-468.496,-957.541,458.922 TIP/T1A90B-90, SHANKIJK=1, 0, 0, ANGLE=-90 MOVE/POINT,-501.039,-784.041,442.736 RPSX2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-510.611,-772.173,456.696,0.9625368,0,-0.2711512 ACTL/-510.621,-772.182,456.696,0.9625368,0,-0.2711512 TARG/-510.611,-772.173,456.696,0.9625368,0,-0.2711512 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 RPSX3 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-538.765,-785.024,390.235,0.9171757,-0.0180034,0.3980762 ACTL/-538.386,-785.032,390.394,0.9171757,-0.0180034,0.3980762 TARG/-538.765,-785.024,390.235,0.9171757,-0.0180034,0.3980762 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-560.201,-838.206,261.229 MOVE/POINT,-785.517,-804.403,260.893 TIP/T1A60B180, SHANKIJK=0, -0.866, 0.5, ANGLE=180 RPSZ1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-631,-743,367.101,-0.0189987,-0.1829873,-0.9829317 ACTL/-631.002,-742.995,367.102,-0.0189987,-0.1829873,-0.9829317 TARG/-631,-743,367.101,-0.0189987,-0.1829873,-0.9829317 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-745.004,-719.868,289.783 RPSZ2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-851,-490,343.963,-0.0519831,-0.076975,-0.995677 ACTL/-850.999,-489.993,343.963,-0.0519831,-0.076975,-0.995677 TARG/-851,-490,343.963,-0.0519831,-0.076975,-0.995677 THEO_THICKNESS = 0, RECT, SNAP = NO ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-987.63,-563.84,358.174 MOVE/POINT,-911.63,-419.368,706.284 TIP/T1A22.5B45, SHANKIJK=-0.877, -0.13, 0.462, ANGLE=-33.983 PC11 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-857.19,-461.37,380,-0.1109793,0.9158292,0.385928 ACTL/-857.193,-461.343,380.011,-0.1109793,0.9158292,0.385928 TARG/-857.19,-461.37,380,-0.1109793,0.9158292,0.385928 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC12 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-804.46,-490.5,449,-0.1169884,0.8449164,0.5219483 ACTL/-804.475,-490.393,449.066,-0.1169884,0.8449164,0.5219483 TARG/-804.46,-490.5,449,-0.1169884,0.8449164,0.5219483 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 MOVE/POINT,-787.149,-472.086,513.293 PC13 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-736,-535,482.91,-0.1670773,-0.0310143,0.9854559 ACTL/-735.879,-534.978,482.196,-0.1670773,-0.0310143,0.9854559 TARG/-736,-535,482.91,-0.1670773,-0.0310143,0.9854559 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 PC14 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-615.3,-660,492,-0.141067,-0.1370651,0.9804658 ACTL/-615.241,-659.942,491.587,-0.141067,-0.1370651,0.9804658 TARG/-615.3,-660,492,-0.141067,-0.1370651,0.9804658 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 A0 =ALIGNMENT/START,RECALL:A1, LIST= YES ALIGNMENT/BF3D,LEASTSQR,ROTANDTRANS,-0.301,-0.786,-2.022,-0.012,-0.095,0.072 SHOWALLINPUTS=NO,SHOWALLPARAMS=NO ALIGNMENT/END MOVESPEED/ 70
2006-11-14 13:17
MOVE/POINT,-749.5,-723.014,597.535 TIP/T1A0B0, SHANKIJK=-0.875, -0.44, 0.204, ANGLE=-83.607 PC1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-858.26,-478,380,-0.8583706,-0.4092232,0.3094127 ACTL/-858.377,-478.056,380.042,-0.8583706,-0.4092232,0.3094127 TARG/-858.26,-478,380,-0.8583706,-0.4092232,0.3094127 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-804.28,-510,449,-0.7261615,-0.358107,0.5868976 ACTL/-804.185,-509.953,448.924,-0.7261615,-0.358107,0.5868976 TARG/-804.28,-510,449,-0.7261615,-0.358107,0.5868976 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC3 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-773.03,-535,468,-0.6166179,-0.3480907,0.7061269 ACTL/-772.943,-534.951,467.901,-0.6166179,-0.3480907,0.7061269 TARG/-773.03,-535,468,-0.6166179,-0.3480907,0.7061269 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC4 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-657.33,-670,474,-0.4701411,-0.5101531,0.7202161 ACTL/-657.43,-670.109,474.154,-0.4701411,-0.5101531,0.7202161 TARG/-657.33,-670,474,-0.4701411,-0.5101531,0.7202161 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC5 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-563.81,-745,470,-0.3970538,-0.6820924,0.6140832 ACTL/-563.88,-745.12,470.108,-0.3970538,-0.6820924,0.6140832 TARG/-563.81,-745,470,-0.3970538,-0.6820924,0.6140832 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC6 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-535.63,-770,454,-0.3490373,-0.832089,0.4310461 ACTL/-535.658,-770.066,454.034,-0.3490373,-0.832089,0.4310461 TARG/-535.63,-770,454,-0.3490373,-0.832089,0.4310461 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC7 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-564.8,-783,385,-0.3520979,-0.9082525,0.2260629 ACTL/-564.81,-783.025,385.006,-0.3520979,-0.9082525,0.2260629 TARG/-564.8,-783,385,-0.3520979,-0.9082525,0.2260629 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 MOVE/POINT,-649.965,-860.013,421.805 PC8 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-640.09,-743,385,-0.5389302,-0.7968968,0.2729647 ACTL/-640.186,-743.142,385.048,-0.5389302,-0.7968968,0.2729647 TARG/-640.09,-743,385,-0.5389302,-0.7968968,0.2729647 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 MOVE/POINT,-681.483,-781.385,403.027 PC9 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-732.43,-677,348,-0.7031456,-0.681141,0.2040422 ACTL/-732.389,-676.96,347.988,-0.7031456,-0.681141,0.2040422 TARG/-732.43,-677,348,-0.7031456,-0.681141,0.2040422 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 PC10 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-795.36,-595,364,-0.7917016,-0.5587894,0.2469069 ACTL/-795.585,-595.159,364.07,-0.7917016,-0.5587894,0.2469069 TARG/-795.36,-595,364,-0.7917016,-0.5587894,0.2469069 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 20 MOVE/POINT,-903.777,-451.322,461.537 TIP/T1A22.5B45, SHANKIJK=-0.882, -0.138, 0.451, ANGLE=-34.455 PC11 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-857.19,-461.37,380,-0.1109793,0.9158292,0.385928 ACTL/-857.202,-461.268,380.043,-0.1109793,0.9158292,0.385928 TARG/-857.19,-461.37,380,-0.1109793,0.9158292,0.385928 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 PC12 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-804.46,-490.5,449,-0.1169884,0.8449164,0.5219483 ACTL/-804.468,-490.444,449.035,-0.1169884,0.8449164,0.5219483 TARG/-804.46,-490.5,449,-0.1169884,0.8449164,0.5219483 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 MOVE/POINT,-787.149,-472.086,513.293 PC13 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-736,-535,482.91,-0.1670773,-0.0310143,0.9854559 ACTL/-735.965,-534.994,482.705,-0.1670773,-0.0310143,0.9854559 TARG/-736,-535,482.91,-0.1670773,-0.0310143,0.9854559 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 PC14 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-615.3,-660,492,-0.141067,-0.1370651,0.9804658 ACTL/-615.29,-659.99,491.929,-0.141067,-0.1370651,0.9804658 TARG/-615.3,-660,492,-0.141067,-0.1370651,0.9804658 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC22 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-573.822,-709.827,483.019,0.0649789,0.079974,0.9946768 ACTL/-573.84,-709.849,482.745,0.0649789,0.079974,0.9946768 TARG/-573.822,-709.827,483.019,0.0649789,0.079974,0.9946768 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 25 PC15 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-531.69,-744.99,480.83,0.1900501,0.0830219,0.9782578 ACTL/-531.746,-745.015,480.541,0.1900501,0.0830219,0.9782578 TARG/-531.69,-744.99,480.83,0.1900501,0.0830219,0.9782578 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 20 MOVE/POINT,-398.29,-890.777,530.478 TIP/T1A90B-90, SHANKIJK=0.451, -0.893, 0.009, ANGLE=-12.816 MOVE/POINT,-550.073,-825.199,465.823 PC16 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-523.08,-777.35,426,0.9175406,-0.0180106,-0.397234 ACTL/-523.228,-777.347,426.064,0.9175406,-0.0180106,-0.397234 TARG/-523.08,-777.35,426,0.9175406,-0.0180106,-0.397234 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 MOVE/POINT,-538.381,-822.985,294.295 MOVE/POINT,-830.882,-757.953,191.68 TIP/T1A60B180, SHANKIJK=-0.591, -0.306, -0.746, ANGLE=69.67 PC23 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-554.923,-782.903,375.096,0.0499749,-0.1559217,-0.9865044 ACTL/-554.906,-782.956,374.763,0.0499749,-0.1559217,-0.9865044 TARG/-554.923,-782.903,375.096,0.0499749,-0.1559217,-0.9865044 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC24 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-606.613,-756.251,369.492,0.0140039,-0.1520423,-0.9882748 ACTL/-606.608,-756.302,369.162,0.0140039,-0.1520423,-0.9882748 TARG/-606.613,-756.251,369.492,0.0140039,-0.1520423,-0.9882748 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC25 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-638.663,-739.668,366.663,-0.02099,-0.1849117,-0.982531 ACTL/-638.668,-739.714,366.42,-0.02099,-0.1849117,-0.982531 TARG/-638.663,-739.668,366.663,-0.02099,-0.1849117,-0.982531 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 PC26 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-666.063,-717.818,353.669,-0.0520165,-0.7302319,-0.6812163 ACTL/-666.074,-717.979,353.518,-0.0520165,-0.7302319,-0.6812163 TARG/-666.063,-717.818,353.669,-0.0520165,-0.7302319,-0.6812163 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 5 MOVE/POINT,-705.275,-701.604,313.459 PC17 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-709,-677,332.54,-0.0520043,-0.2330193,-0.9710806 ACTL/-709.014,-677.064,332.272,-0.0520043,-0.2330193,-0.9710806 TARG/-709,-677,332.54,-0.0520043,-0.2330193,-0.9710806 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-775.379,-634.938,305.287 PC27 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-763.214,-620.151,343.244,-0.0520018,0.4920175,-0.8690309 ACTL/-763.22,-620.096,343.146,-0.0520018,0.4920175,-0.8690309 TARG/-763.214,-620.151,343.244,-0.0520018,0.4920175,-0.8690309 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC18 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-774,-595,350.04,-0.0520274,-0.1190628,-0.9915227 ACTL/-773.99,-594.977,350.228,-0.0520274,-0.1190628,-0.9915227 TARG/-774,-595,350.04,-0.0520274,-0.1190628,-0.9915227 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 PC19 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-822.847,-541.343,346.882,-0.052011,-0.0940199,-0.9942108 ACTL/-822.838,-541.327,347.047,-0.052011,-0.0940199,-0.9942108 TARG/-822.847,-541.343,346.882,-0.052011,-0.0940199,-0.9942108 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC20 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-847.33,-493.328,344.029,-0.0519791,-0.0779687,-0.9955998 ACTL/-847.321,-493.314,344.204,-0.0519791,-0.0779687,-0.9955998 TARG/-847.33,-493.328,344.029,-0.0519791,-0.0779687,-0.9955998 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 15 PC21 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-867.112,-459.833,350.128,-0.0540005,0.7580076,-0.6500065 ACTL/-867.106,-459.918,350.201,-0.0540005,0.7580076,-0.6500065 TARG/-867.112,-459.833,350.128,-0.0540005,0.7580076,-0.6500065 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 25 MOVE/POINT,-1137.366,-575.836,391.32 TIP/T1A22.5B45, SHANKIJK=-0.771, -0.285, 0.57, ANGLE=-23.072 MOVE/POINT,-870.289,-462.786,471.585
2006-11-14 13:21
P1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-790.075,-449.221,417.856,-0.9774453,0.1880857,0.0960438 ACTL/-789.857,-449.263,417.835,-0.9774453,0.1880857,0.0960438 TARG/-790.075,-449.221,417.856,-0.9774453,0.1880857,0.0960438 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 P2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-788.391,-451.042,419.713,-0.0759834,-0.4379045,0.8958047 ACTL/-788.367,-450.901,419.425,-0.0759834,-0.4379045,0.8958047 TARG/-788.391,-451.042,419.713,-0.0759834,-0.4379045,0.8958047 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 MOVE/POINT,-837.481,-458.295,539.553 P3 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-720.113,-540.33,489.175,-0.9889382,0.0099994,0.1479908 ACTL/-719.919,-540.332,489.146,-0.9889382,0.0099994,0.1479908 TARG/-720.113,-540.33,489.175,-0.9889382,0.0099994,0.1479908 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 P4 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-718.718,-542.965,489.281,0,-0.9978204,0.0659881 ACTL/-718.718,-542.954,489.28,0,-0.9978204,0.0659881 TARG/-718.718,-542.965,489.281,0,-0.9978204,0.0659881 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 MOVE/POINT,-733.404,-560.261,496.091 MOVE/POINT,-634.812,-660.723,505.819 P5 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-610.059,-654.683,497.317,-0.977394,-0.0120048,0.2110851 ACTL/-610.099,-654.683,497.326,-0.977394,-0.0120048,0.2110851 TARG/-610.059,-654.683,497.317,-0.977394,-0.0120048,0.2110851 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 P6 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-608.705,-657.319,496.495,0,-0.9984879,-0.0549718 ACTL/-608.705,-657.606,496.479,0,-0.9984879,-0.0549718 TARG/-608.705,-657.319,496.495,0,-0.9984879,-0.0549718 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 MOVE/POINT,-608.778,-703.843,541.931 MOVE/POINT,-498.281,-953.533,508.615 TIP/T1A45B-90, SHANKIJK=-0.3, -0.942, 0.151, ANGLE=-162.66 MOVE/POINT,-504.285,-785.535,456.416 P7 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-498.972,-768.359,455.777,-0.940078,-0.325027,0.1030086 ACTL/-499.23,-768.448,455.805,-0.940078,-0.325027,0.1030086 TARG/-498.972,-768.359,455.777,-0.940078,-0.325027,0.1030086 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 3 P8 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-497.886,-768.826,453.183,0,-0.3008921,-0.9536582 ACTL/-497.886,-768.871,453.04,0,-0.3008921,-0.9536582 TARG/-497.886,-768.826,453.183,0,-0.3008921,-0.9536582 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 10 MOVE/POINT,-523.037,-789.157,410.801 P9 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-522.695,-779.874,400.028,-0.940078,-0.325027,0.1030086 ACTL/-522.795,-779.909,400.039,-0.940078,-0.325027,0.1030086 TARG/-522.695,-779.874,400.028,-0.940078,-0.325027,0.1030086 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 3 P10 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-521.609,-780.102,397.338,0,-0.3008921,-0.9536582 ACTL/-521.609,-780.196,397.041,0,-0.3008921,-0.9536582 TARG/-521.609,-780.102,397.338,0,-0.3008921,-0.9536582 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 MOVE/POINT,-529.153,-806.52,357.205 MOVE/POINT,-606.99,-852.578,237.919 TIP/T1A45B-120, SHANKIJK=-0.405, -0.893, -0.196, ANGLE=127.006 P11 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-597.089,-735.652,342.6,-0.0329896,-0.9177114,0.3958755 ACTL/-597.086,-735.565,342.562,-0.0329896,-0.9177114,0.3958755 TARG/-597.089,-735.652,342.6,-0.0329896,-0.9177114,0.3958755 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 P12 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-598.076,-733.464,341.027,-0.9289229,-0.1179902,-0.3509709 ACTL/-598.215,-733.482,340.974,-0.9289229,-0.1179902,-0.3509709 TARG/-598.076,-733.464,341.027,-0.9289229,-0.1179902,-0.3509709 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 MOVE/POINT,-644.251,-753.402,288.857 MOVE/POINT,-798.501,-562.795,297.415 P13 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-777.35,-530.513,334.143,0,-0.9989416,-0.0459973 ACTL/-777.35,-530.368,334.15,0,-0.9989416,-0.0459973 TARG/-777.35,-530.513,334.143,0,-0.9989416,-0.0459973 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 P14 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-778.514,-527.828,334.177,-0.9347635,0.015996,-0.3549102 ACTL/-778.566,-527.827,334.157,-0.9347635,0.015996,-0.3549102 TARG/-778.514,-527.828,334.177,-0.9347635,0.015996,-0.3549102 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 MOVE/POINT,-872.965,-500.15,156.459 TIP/T1A90B180, SHANKIJK=-0.178, -0.1, -0.979, ANGLE=63.779 MOVE/POINT,-816.766,-439.893,305.665 A1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-817.708,-431.71,340.721,0.0549951,0.6569415,-0.7519331 ACTL/-817.684,-431.418,340.387,0.0549951,0.6569415,-0.7519331 TARG/-817.708,-431.71,340.721,0.0549951,0.6569415,-0.7519331 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 G1 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-813.291,-437.663,337.663,0.9686581,0.2319181,0.0889686 ACTL/-814.611,-437.979,337.542,0.9686581,0.2319181,0.0889686 TARG/-813.291,-437.663,337.663,0.9686581,0.2319181,0.0889686 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = YES, DISTANCE = 8 MOVE/POINT,-816.846,-446.11,296.974 MOVE/POINT,-934.256,-306.803,294.366 MOVE/POINT,-843.663,-224.224,626.425 TIP/T1A90B90, SHANKIJK=-0.451, 0.893, -0.009, ANGLE=12.816 A2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-759.84,-474.819,464.367,-0.0490071,0.8901291,0.4530657 ACTL/-759.835,-474.907,464.322,-0.0490071,0.8901291,0.4530657 TARG/-759.84,-474.819,464.367,-0.0490071,0.8901291,0.4530657 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 G2 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-755.626,-474.205,462.339,0.9000351,0.2610102,-0.3490136 ACTL/-755.903,-474.285,462.447,0.9000351,0.2610102,-0.3490136 TARG/-755.626,-474.205,462.339,0.9000351,0.2610102,-0.3490136 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-712.556,-450.934,678.606 MOVE/POINT,-623.354,-609.791,718.761 TIP/T1A90B0, SHANKIJK=0.178, 0.1, 0.979, ANGLE=-63.779 A3 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-691.751,-567.258,489.158,-0.0529932,0.0379951,0.9978718 ACTL/-691.731,-567.272,488.786,-0.0529932,0.0379951,0.9978718 TARG/-691.751,-567.258,489.158,-0.0529932,0.0379951,0.9978718 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 G3 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-688.572,-565.589,488.441,0.749629,0.64668,0.1409303 ACTL/-688.64,-565.648,488.428,0.749629,0.64668,0.1409303 TARG/-688.572,-565.589,488.441,0.749629,0.64668,0.1409303 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-676.226,-557.741,540.652 MOVE/POINT,-523.25,-698.701,521.178 A4 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-527.305,-713.355,479.633,0.0300116,0.018007,0.9993873 ACTL/-527.321,-713.365,479.085,0.0300116,0.018007,0.9993873 TARG/-527.305,-713.355,479.633,0.0300116,0.018007,0.9993873 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 G4 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-524.334,-713.397,478.661,0.7431449,0.6691305,0 ACTL/-524.621,-713.655,478.661,0.7431449,0.6691305,0 TARG/-524.334,-713.397,478.661,0.7431449,0.6691305,0 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-495.973,-697.967,472.748 MOVE/POINT,-397.194,-893.603,474.783 MOVE/POINT,-434.485,-900.065,300.652 TIP/T1A90B-90, SHANKIJK=0.451, -0.893, 0.009, ANGLE=-12.816 MOVE/POINT,-463.398,-779.924,436.092 A5 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-509.957,-774.195,418.586,0.057025,-0.9834318,0.1720756 ACTL/-509.97,-773.973,418.547,0.057025,-0.9834318,0.1720756 TARG/-509.957,-774.195,418.586,0.057025,-0.9834318,0.1720756 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 G5 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-507.959,-773.318,417.873,0.9188851,-0.0449944,-0.391951 ACTL/-508.151,-773.309,417.955,0.9188851,-0.0449944,-0.391951 TARG/-507.959,-773.318,417.873,0.9188851,-0.0449944,-0.391951 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-552.299,-860.584,161.504 MOVE/POINT,-686.637,-712.094,139.638 TIP/T1A90B180, SHANKIJK=-0.178, -0.1, -0.979, ANGLE=63.779 A6 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-623.65,-696.332,330.798,0.1059894,-0.069993,-0.9919008 ACTL/-623.668,-696.32,330.967,0.1059894,-0.069993,-0.9919008 TARG/-623.65,-696.332,330.798,0.1059894,-0.069993,-0.9919008 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 G6 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-622.198,-694.665,331.589,0.7190047,0.6950045,0.001 ACTL/-622.411,-694.871,331.589,0.7190047,0.6950045,0.001 TARG/-622.198,-694.665,331.589,0.7190047,0.6950045,0.001 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-611.726,-688.253,312.688 MOVE/POINT,-688.361,-543.505,295.968 A7 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-745.049,-569.597,337.6,0.1010421,0.0540225,-0.9934143 ACTL/-745.1,-569.624,338.097,0.1010421,0.0540225,-0.9934143 TARG/-745.049,-569.597,337.6,0.1010421,0.0540225,-0.9934143 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 G7 =AUTO/VECTOR POINT, SHOWALLPARAMS=YES THEO/-743.038,-568.421,338.742,0.8338712,0.5519147,-0.0069989 ACTL/-743.169,-568.508,338.743,0.8338712,0.5519147,-0.0069989 TARG/-743.038,-568.421,338.742,0.8338712,0.5519147,-0.0069989 THEO_THICKNESS = 0, RECT, SNAP = YES ,$ AUTO MOVE = NO, DISTANCE = 10 MOVE/POINT,-761.873,-578.696,216.664 MOVE/POINT,-1215.479,-806.634,322.298
2006-11-14 13:22
DIM LOC1= LOCATION OF POINT PC1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -858.260 0.500 0.500 -858.377 -0.117 ---#----- Y -478.000 0.500 0.500 -478.056 -0.056 ---#----- Z 380.000 0.500 0.500 380.042 0.042 ----#---- T 0.000 0.500 0.500 0.137 0.137 -----#--- END OF DIMENSION LOC1 DIMINFO/LOC1;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC3= LOCATION OF POINT PC2 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -804.280 0.500 0.500 -804.185 0.095 -----#--- Y -510.000 0.500 0.500 -509.953 0.047 ----#---- Z 449.000 0.500 0.500 448.924 -0.076 ---#----- T 0.000 0.500 0.500 -0.130 -0.130 ---#----- END OF DIMENSION LOC3 DIMINFO/LOC3;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC4= LOCATION OF POINT PC3 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -773.030 0.500 0.500 -772.943 0.087 -----#--- Y -535.000 0.500 0.500 -534.951 0.049 ----#---- Z 468.000 0.500 0.500 467.901 -0.099 ---#----- T 0.000 0.500 0.500 -0.141 -0.141 ---#----- END OF DIMENSION LOC4 DIMINFO/LOC4;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC5= LOCATION OF POINT PC4 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -657.330 0.500 0.500 -657.430 -0.100 ---#----- Y -670.000 0.500 0.500 -670.109 -0.109 ---#----- Z 474.000 0.500 0.500 474.154 0.154 -----#--- T 0.000 0.500 0.500 0.213 0.213 ------#-- END OF DIMENSION LOC5 DIMINFO/LOC5;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC6= LOCATION OF POINT PC5 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -563.810 0.500 0.500 -563.880 -0.070 ---#----- Y -745.000 0.500 0.500 -745.120 -0.120 ---#----- Z 470.000 0.500 0.500 470.108 0.108 -----#--- T 0.000 0.500 0.500 0.175 0.175 ------#-- END OF DIMENSION LOC6 DIMINFO/LOC6;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC7= LOCATION OF POINT PC6 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -535.630 0.500 0.500 -535.658 -0.028 ----#---- Y -770.000 0.500 0.500 -770.066 -0.066 ---#----- Z 454.000 0.500 0.500 454.034 0.034 ----#---- T 0.000 0.500 0.500 0.079 0.079 -----#--- END OF DIMENSION LOC7 DIMINFO/LOC7;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC8= LOCATION OF POINT PC7 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -564.800 0.500 0.500 -564.810 -0.010 ----#---- Y -783.000 0.500 0.500 -783.025 -0.025 ----#---- Z 385.000 0.500 0.500 385.006 0.006 ----#---- T 0.000 0.500 0.500 0.027 0.027 ----#---- END OF DIMENSION LOC8 DIMINFO/LOC8;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC9= LOCATION OF POINT PC8 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -640.090 0.500 0.500 -640.186 -0.096 ---#----- Y -743.000 0.500 0.500 -743.142 -0.142 ---#----- Z 385.000 0.500 0.500 385.048 0.048 ----#---- T 0.000 0.500 0.500 0.178 0.178 ------#-- END OF DIMENSION LOC9 DIMINFO/LOC9;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC10= LOCATION OF POINT PC9 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -732.430 0.500 0.500 -732.389 0.041 ----#---- Y -677.000 0.500 0.500 -676.960 0.040 ----#---- Z 348.000 0.500 0.500 347.988 -0.012 ----#---- T 0.000 0.500 0.500 -0.059 -0.059 ---#----- END OF DIMENSION LOC10 DIMINFO/LOC10;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC11= LOCATION OF POINT PC10 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -795.360 0.500 0.500 -795.585 -0.225 --#------ Y -595.000 0.500 0.500 -595.159 -0.159 ---#----- Z 364.000 0.500 0.500 364.070 0.070 -----#--- T 0.000 0.500 0.500 0.284 0.284 -------#- END OF DIMENSION LOC11 DIMINFO/LOC11;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC12= LOCATION OF POINT PC11 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -857.190 0.500 0.500 -857.202 -0.012 ----#---- Y -461.370 0.500 0.500 -461.268 0.102 -----#--- Z 380.000 0.500 0.500 380.043 0.043 ----#---- T 0.000 0.500 0.500 0.111 0.111 -----#--- END OF DIMENSION LOC12 DIMINFO/LOC12;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC13= LOCATION OF POINT PC12 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -804.460 0.500 0.500 -804.468 -0.008 ----#---- Y -490.500 0.500 0.500 -490.444 0.056 -----#--- Z 449.000 0.500 0.500 449.035 0.035 ----#---- T 0.000 0.500 0.500 0.067 0.067 -----#--- END OF DIMENSION LOC13 DIMINFO/LOC13;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC14= LOCATION OF POINT PC13 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -736.000 0.500 0.500 -735.965 0.035 ----#---- Y -535.000 0.500 0.500 -534.994 0.006 ----#---- Z 482.910 0.500 0.500 482.705 -0.205 --#------ T 0.000 0.500 0.500 -0.208 -0.208 --#------ END OF DIMENSION LOC14 DIMINFO/LOC14;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC15= LOCATION OF POINT PC14 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -615.300 0.500 0.500 -615.290 0.010 ----#---- Y -660.000 0.500 0.500 -659.990 0.010 ----#---- Z 492.000 0.500 0.500 491.929 -0.071 ---#----- T 0.000 0.500 0.500 -0.072 -0.072 ---#----- END OF DIMENSION LOC15 DIMINFO/LOC15;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC16= LOCATION OF POINT PC15 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -531.690 0.500 0.500 -531.746 -0.056 ---#----- Y -744.990 0.500 0.500 -745.015 -0.025 ----#---- Z 480.830 0.500 0.500 480.541 -0.289 -#------- T 0.000 0.500 0.500 -0.296 -0.296 -#------- END OF DIMENSION LOC16 DIMINFO/LOC16;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC17= LOCATION OF POINT PC16 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -523.080 0.500 0.500 -523.228 -0.148 ---#----- Y -777.350 0.500 0.500 -777.347 0.003 ----#---- Z 426.000 0.500 0.500 426.064 0.064 -----#--- T 0.000 0.500 0.500 -0.161 -0.161 ---#----- END OF DIMENSION LOC17 DIMINFO/LOC17;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC18= LOCATION OF POINT PC17 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -709.000 0.500 0.500 -709.014 -0.014 ----#---- Y -677.000 0.500 0.500 -677.064 -0.064 ---#----- Z 332.540 0.500 0.500 332.272 -0.268 --#------ T 0.000 0.500 0.500 0.276 0.276 ------#-- END OF DIMENSION LOC18 DIMINFO/LOC18;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC19= LOCATION OF POINT PC18 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -774.000 0.500 0.500 -773.990 0.010 ----#---- Y -595.000 0.500 0.500 -594.977 0.023 ----#---- Z 350.040 0.500 0.500 350.228 0.188 ------#-- T 0.000 0.500 0.500 -0.190 -0.190 --#------ END OF DIMENSION LOC19 DIMINFO/LOC19;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC20= LOCATION OF POINT PC19 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -822.847 0.500 0.500 -822.838 0.009 ----#---- Y -541.343 0.500 0.500 -541.327 0.016 ----#---- Z 346.882 0.500 0.500 347.047 0.165 -----#--- T 0.000 0.500 0.500 -0.166 -0.166 ---#----- END OF DIMENSION LOC20 DIMINFO/LOC20;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC21= LOCATION OF POINT PC20 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -847.330 0.500 0.500 -847.321 0.009 ----#---- Y -493.328 0.500 0.500 -493.314 0.014 ----#---- Z 344.029 0.500 0.500 344.204 0.175 ------#-- T 0.000 0.500 0.500 -0.176 -0.176 --#------ END OF DIMENSION LOC21 DIMINFO/LOC21;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC22= LOCATION OF POINT PC21 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -867.112 0.500 0.500 -867.106 0.006 ----#---- Y -459.833 0.500 0.500 -459.918 -0.085 ---#----- Z 350.128 0.500 0.500 350.201 0.073 -----#--- T 0.000 0.500 0.500 -0.113 -0.113 ---#----- END OF DIMENSION LOC22 DIMINFO/LOC22;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC23= LOCATION OF POINT PC22 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -573.822 0.500 0.500 -573.840 -0.018 ----#---- Y -709.827 0.500 0.500 -709.849 -0.022 ----#---- Z 483.019 0.500 0.500 482.745 -0.274 --#------ T 0.000 0.500 0.500 -0.275 -0.275 --#------ END OF DIMENSION LOC23 DIMINFO/LOC23;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC24= LOCATION OF POINT PC23 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -554.923 0.500 0.500 -554.906 0.017 ----#---- Y -782.903 0.500 0.500 -782.956 -0.053 ----#---- Z 375.096 0.500 0.500 374.763 -0.333 -#------- T 0.000 0.500 0.500 0.338 0.338 -------#- END OF DIMENSION LOC24 DIMINFO/LOC24;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC25= LOCATION OF POINT PC24 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -606.613 0.500 0.500 -606.608 0.005 ----#---- Y -756.251 0.500 0.500 -756.302 -0.051 ----#---- Z 369.492 0.500 0.500 369.162 -0.330 -#------- T 0.000 0.500 0.500 0.333 0.333 -------#- END OF DIMENSION LOC25 DIMINFO/LOC25;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC26= LOCATION OF POINT PC25 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -638.663 0.500 0.500 -638.668 -0.005 ----#---- Y -739.668 0.500 0.500 -739.714 -0.046 ----#---- Z 366.663 0.500 0.500 366.420 -0.243 --#------ T 0.000 0.500 0.500 0.248 0.248 ------#-- END OF DIMENSION LOC26 DIMINFO/LOC26;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC27= LOCATION OF POINT PC26 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -666.063 0.500 0.500 -666.074 -0.011 ----#---- Y -717.818 0.500 0.500 -717.979 -0.161 ---#----- Z 353.669 0.500 0.500 353.518 -0.151 ---#----- T 0.000 0.500 0.500 0.221 0.221 ------#-- END OF DIMENSION LOC27 DIMINFO/LOC27;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC28= LOCATION OF POINT PC27 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -763.214 0.500 0.500 -763.220 -0.006 ----#---- Y -620.151 0.500 0.500 -620.096 0.055 ----#---- Z 343.244 0.500 0.500 343.146 -0.098 ---#----- T 0.000 0.500 0.500 0.112 0.112 -----#--- END OF DIMENSION LOC28 DIMINFO/LOC28;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , 1 =VIEWSET/ RECALL/VIEWSET,1
2006-11-14 13:24
DIM LOC2= LOCATION OF POINT P1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -790.075 0.500 0.500 -789.857 0.218 ------#-- Y -449.221 0.500 0.500 -449.263 -0.042 ----#---- Z 417.856 0.500 0.500 417.835 -0.021 ----#---- T 0.000 0.500 0.500 -0.223 -0.223 --#------ END OF DIMENSION LOC2 DIMINFO/LOC2;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC29= LOCATION OF POINT P2 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -788.391 0.500 0.500 -788.367 0.024 ----#---- Y -451.042 0.500 0.500 -450.901 0.141 -----#--- Z 419.713 0.500 0.500 419.425 -0.288 -#------- T 0.000 0.500 0.500 -0.321 -0.321 -#------- END OF DIMENSION LOC29 DIMINFO/LOC29;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC30= LOCATION OF POINT P3 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -720.113 0.500 0.500 -719.919 0.194 ------#-- Y -540.330 0.500 0.500 -540.332 -0.002 ----#---- Z 489.175 0.500 0.500 489.146 -0.029 ----#---- T 0.000 0.500 0.500 -0.197 -0.197 --#------ END OF DIMENSION LOC30 DIMINFO/LOC30;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC31= LOCATION OF POINT P4 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -718.718 0.500 0.500 -718.718 0.000 ----#---- Y -542.965 0.500 0.500 -542.954 0.011 ----#---- Z 489.281 0.500 0.500 489.280 -0.001 ----#---- T 0.000 0.500 0.500 -0.011 -0.011 ----#---- END OF DIMENSION LOC31 DIMINFO/LOC31;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC32= LOCATION OF POINT P5 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -610.059 0.500 0.500 -610.099 -0.040 ----#---- Y -654.683 0.500 0.500 -654.683 0.000 ----#---- Z 497.317 0.500 0.500 497.326 0.009 ----#---- T 0.000 0.500 0.500 0.041 0.041 ----#---- END OF DIMENSION LOC32 DIMINFO/LOC32;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC33= LOCATION OF POINT P6 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -608.705 0.500 0.500 -608.705 0.000 ----#---- Y -657.319 0.500 0.500 -657.606 -0.287 -#------- Z 496.495 0.500 0.500 496.479 -0.016 ----#---- T 0.000 0.500 0.500 0.288 0.288 -------#- END OF DIMENSION LOC33 DIMINFO/LOC33;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC34= LOCATION OF POINT P7 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -498.972 0.500 0.500 -499.230 -0.258 --#------ Y -768.359 0.500 0.500 -768.448 -0.089 ---#----- Z 455.777 0.500 0.500 455.805 0.028 ----#---- T 0.000 0.500 0.500 0.275 0.275 ------#-- END OF DIMENSION LOC34 DIMINFO/LOC34;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC35= LOCATION OF POINT P8 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -497.886 0.500 0.500 -497.886 0.000 ----#---- Y -768.826 0.500 0.500 -768.871 -0.045 ----#---- Z 453.183 0.500 0.500 453.040 -0.143 ---#----- T 0.000 0.500 0.500 0.150 0.150 -----#--- END OF DIMENSION LOC35 DIMINFO/LOC35;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC36= LOCATION OF POINT P9 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -522.695 0.500 0.500 -522.795 -0.100 ---#----- Y -779.874 0.500 0.500 -779.909 -0.035 ----#---- Z 400.028 0.500 0.500 400.039 0.011 ----#---- T 0.000 0.500 0.500 0.107 0.107 -----#--- END OF DIMENSION LOC36 DIMINFO/LOC36;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC37= LOCATION OF POINT P10 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -521.609 0.500 0.500 -521.609 0.000 ----#---- Y -780.102 0.500 0.500 -780.196 -0.094 ---#----- Z 397.338 0.500 0.500 397.041 -0.297 -#------- T 0.000 0.500 0.500 0.311 0.311 -------#- END OF DIMENSION LOC37 DIMINFO/LOC37;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC38= LOCATION OF POINT P11 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -597.089 0.500 0.500 -597.086 0.003 ----#---- Y -735.652 0.500 0.500 -735.565 0.087 -----#--- Z 342.600 0.500 0.500 342.562 -0.038 ----#---- T 0.000 0.500 0.500 -0.095 -0.095 ---#----- END OF DIMENSION LOC38 DIMINFO/LOC38;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC39= LOCATION OF POINT P12 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -598.076 0.500 0.500 -598.215 -0.139 ---#----- Y -733.464 0.500 0.500 -733.482 -0.018 ----#---- Z 341.027 0.500 0.500 340.974 -0.053 ----#---- T 0.000 0.500 0.500 0.150 0.150 -----#--- END OF DIMENSION LOC39 DIMINFO/LOC39;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC40= LOCATION OF POINT P13 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -777.350 0.500 0.500 -777.350 0.000 ----#---- Y -530.513 0.500 0.500 -530.368 0.145 -----#--- Z 334.143 0.500 0.500 334.150 0.007 ----#---- T 0.000 0.500 0.500 -0.145 -0.145 ---#----- END OF DIMENSION LOC40 DIMINFO/LOC40;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC41= LOCATION OF POINT P14 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -778.514 0.500 0.500 -778.566 -0.052 ----#---- Y -527.828 0.500 0.500 -527.827 0.001 ----#---- Z 334.177 0.500 0.500 334.157 -0.020 ----#---- T 0.000 0.500 0.500 0.056 0.056 -----#--- END OF DIMENSION LOC41 DIMINFO/LOC41;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , 2 =VIEWSET/ RECALL/VIEWSET,2
2006-11-14 13:24
DIM LOC68= LOCATION OF POINT A1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -817.708 0.500 0.500 -817.684 0.024 ----#---- Y -431.710 0.500 0.500 -431.418 0.292 -------#- Z 340.721 0.500 0.500 340.387 -0.334 -#------- T 0.000 0.500 0.500 0.444 0.444 --------# END OF DIMENSION LOC68 DIMINFO/LOC68;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC69= LOCATION OF POINT G1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -813.291 0.500 0.500 -814.611 -1.320 <-------- Y -437.663 0.500 0.500 -437.979 -0.316 -#------- Z 337.663 0.500 0.500 337.542 -0.121 ---#----- T 0.000 0.500 0.500 -1.363 -1.363 <-------- END OF DIMENSION LOC69 DIMINFO/LOC69;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC70= LOCATION OF POINT A2 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -759.840 0.500 0.500 -759.835 0.005 ----#---- Y -474.819 0.500 0.500 -474.907 -0.088 ---#----- Z 464.367 0.500 0.500 464.322 -0.045 ----#---- T 0.000 0.500 0.500 -0.099 -0.099 ---#----- END OF DIMENSION LOC70 DIMINFO/LOC70;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC71= LOCATION OF POINT G2 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -755.626 0.500 0.500 -755.903 -0.277 --#------ Y -474.205 0.500 0.500 -474.285 -0.080 ---#----- Z 462.339 0.500 0.500 462.447 0.108 -----#--- T 0.000 0.500 0.500 -0.308 -0.308 -#------- END OF DIMENSION LOC71 DIMINFO/LOC71;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC72= LOCATION OF POINT A3 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -691.751 0.500 0.500 -691.731 0.020 ----#---- Y -567.258 0.500 0.500 -567.272 -0.014 ----#---- Z 489.158 0.500 0.500 488.786 -0.372 -#------- T 0.000 0.500 0.500 -0.373 -0.373 -#------- END OF DIMENSION LOC72 DIMINFO/LOC72;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC73= LOCATION OF POINT G3 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -688.572 0.500 0.500 -688.640 -0.068 ---#----- Y -565.589 0.500 0.500 -565.648 -0.059 ---#----- Z 488.441 0.500 0.500 488.428 -0.013 ----#---- T 0.000 0.500 0.500 -0.091 -0.091 ---#----- END OF DIMENSION LOC73 DIMINFO/LOC73;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC74= LOCATION OF POINT A4 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -527.305 0.500 0.500 -527.321 -0.016 ----#---- Y -713.355 0.500 0.500 -713.365 -0.010 ----#---- Z 479.633 0.500 0.500 479.085 -0.548 <-------- T 0.000 0.500 0.500 -0.548 -0.548 <-------- END OF DIMENSION LOC74 DIMINFO/LOC74;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC75= LOCATION OF POINT G4 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -524.334 0.500 0.500 -524.621 -0.287 -#------- Y -713.397 0.500 0.500 -713.655 -0.258 --#------ Z 478.661 0.500 0.500 478.661 0.000 ----#---- T 0.000 0.500 0.500 -0.386 -0.386 -#------- END OF DIMENSION LOC75 DIMINFO/LOC75;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC76= LOCATION OF POINT A5 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -509.957 0.500 0.500 -509.970 -0.013 ----#---- Y -774.195 0.500 0.500 -773.973 0.222 ------#-- Z 418.586 0.500 0.500 418.547 -0.039 ----#---- T 0.000 0.500 0.500 -0.226 -0.226 --#------ END OF DIMENSION LOC76 DIMINFO/LOC76;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC77= LOCATION OF POINT G5 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -507.959 0.500 0.500 -508.151 -0.192 --#------ Y -773.318 0.500 0.500 -773.309 0.009 ----#---- Z 417.873 0.500 0.500 417.955 0.082 -----#--- T 0.000 0.500 0.500 -0.209 -0.209 --#------ END OF DIMENSION LOC77 DIMINFO/LOC77;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC78= LOCATION OF POINT A6 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -623.650 0.500 0.500 -623.668 -0.018 ----#---- Y -696.332 0.500 0.500 -696.320 0.012 ----#---- Z 330.798 0.500 0.500 330.967 0.169 ------#-- T 0.000 0.500 0.500 -0.170 -0.170 --#------ END OF DIMENSION LOC78 DIMINFO/LOC78;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC79= LOCATION OF POINT G6 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -622.198 0.500 0.500 -622.411 -0.213 --#------ Y -694.665 0.500 0.500 -694.871 -0.206 --#------ Z 331.589 0.500 0.500 331.589 0.000 ----#---- T 0.000 0.500 0.500 -0.296 -0.296 -#------- END OF DIMENSION LOC79 DIMINFO/LOC79;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC80= LOCATION OF POINT A7 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -745.049 0.500 0.500 -745.100 -0.051 ----#---- Y -569.597 0.500 0.500 -569.624 -0.027 ----#---- Z 337.600 0.500 0.500 338.097 0.497 --------# T 0.000 0.500 0.500 -0.501 -0.501 <-------- END OF DIMENSION LOC80 DIMINFO/LOC80;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , DIM LOC81= LOCATION OF POINT G7 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV X -743.038 0.500 0.500 -743.169 -0.131 ---#----- Y -568.421 0.500 0.500 -568.508 -0.087 ---#----- Z 338.742 0.500 0.500 338.743 0.001 ----#---- T 0.000 0.500 0.500 -0.157 -0.157 ---#----- END OF DIMENSION LOC81 DIMINFO/LOC81;DIMID,FEATID;HEADINGS, ;DEV, , , , , , , , ,$ T,X,Y,Z, , , , , , , , , , , , , 3 =VIEWSET/ RECALL/VIEWSET,3
2006-11-14 13:25
以上是一个完整的程序,需要保存视图3张。我们只有将光标放到 3 =VIEWSET/ RECALL/VIEWSET,3 才能看到第3张视图,放到 1 =VIEWSET/ RECALL/VIEWSET,1 和 2 =VIEWSET/ RECALL/VIEWSET,2 后面就看不到视图了,只有图形没有标示。
2006-11-14 13:33
.                   [此贴子已经被作者于2006-12-5 12:41:06编辑过]
2006-11-14 16:56
