社区活动 技术论坛 跪求有关X3或者X5测头的资料
跪求有关X3或者X5测头的资料
2012-05-07 08:16 166 0 4
各位高手:诚求X3或X5测头的资料(优点),谢谢
2012-05-07 08:16
以下页面的第一个文件就是Hexagon的测头信息资料: [url]http://www.hexagonmetrology.com/downloads.htm?cid=11088[/url]
2012-05-07 11:21
[b]回复 [url=http://bbs.hexagonmetrology.com.cn:6080/showtopic.aspx?topicid=11362&postid=87483#87483]2楼[color=olive]ssl2000[/color]的帖子[/url][/b] 谢谢。。。。。可惜是英文版本的
2012-05-08 08:09
The LSP-X3c fixed scanning probe head is compact, fast and accurate. It can carry up to 360 mm long probing extensions. The LSP-X3c offers effective Single Point Probing in all standard metro- logy tasks as well as continuous High-Speed-Scanning for form and profile inspection of complex geometric elements (cylinder gears, worm gears, turbine blades, worm screws etc.). Probe trigger force is measured by high resolution linear variable differential transducers (LVDT) allowing the cor- rect compensation for stylus deflection even when long extensions are fitted, and to automatically measure in a direction orthogonal to the part.
2013-09-10 20:48
