社区活动 技术论坛 [推荐]机械相关专业词汇中英文对照
[推荐]机械相关专业词汇中英文对照
2007-03-28 16:32 824 0 35
阿基米德蜗杆 Archimedes worm 安全系数 safety factor; factor of safety 安全载荷 safe load 凹面、凹度 concavity 扳手 wrench 板簧 flat leaf spring 半圆键 woodruff key 变形 deformation 摆杆 oscillating bar 摆动从动件 oscillating follower 摆动从动件凸轮机构 cam with oscillating follower 摆动导杆机构 oscillating guide-bar mechanism 摆线齿轮 cycloidal gear 摆线齿形 cycloidal tooth profile 摆线运动规律 cycloidal motion 摆线针轮 cycloidal-pin wheel 包角 angle of contact 保持架 cage 背对背安装 back-to-back arrangement 背锥 back cone ; normal cone 背锥角 back angle 背锥距 back cone distance 比例尺 scale 比热容 specific heat capacity 闭式链 closed kinematic chain 闭链机构 closed chain mechanism 臂部 arm 变频器 frequency converters 变频调速 frequency control of motor speed 变速 speed change 变速齿轮 change gear ; change wheel 变位齿轮 modified gear 变位系数 modification coefficient 标准齿轮 standard gear 标准直齿轮 standard spur gear 表面质量系数 superficial mass factor 表面传热系数 surface coefficient of heat transfer 表面粗糙度 surface roughness 并联式组合 combination in parallel 并联机构 parallel mechanism 并联组合机构 parallel combined mechanism 并行工程 concurrent engineering 并行设计 concurred design, CD 不平衡相位 phase angle of unbalance 不平衡 imbalance (or unbalance) 不平衡量 amount of unbalance 不完全齿轮机构 intermittent gearing 波发生器 wave generator 波数 number of waves 补偿 compensation 参数化设计 parameterization design, PD 残余应力 residual stress 操纵及控制装置 operation control device 槽轮 Geneva wheel 槽轮机构 Geneva mechanism ; Maltese cross 槽数 Geneva numerate 槽凸轮 groove cam 侧隙 backlash 差动轮系 differential gear train 差动螺旋机构 differential screw mechanism 差速器 differential 常用机构 conventional mechanism; mechanism in common use 车床 lathe 承载量系数 bearing capacity factor 承载能力 bearing capacity 成对安装 paired mounting 尺寸系列 dimension series 齿槽 tooth space 齿槽宽 spacewidth 齿侧间隙 backlash 齿顶高 addendum 齿顶圆 addendum circle 齿根高 dedendum 齿根圆 dedendum circle 齿厚 tooth thickness 齿距 circular pitch 齿宽 face width 齿廓 tooth profile 齿廓曲线 tooth curve 齿轮 gear 齿轮变速箱 speed-changing gear boxes 齿轮齿条机构 pinion and rack 齿轮插刀 pinion cutter; pinion-shaped shaper cutter 齿轮滚刀 hob ,hobbing cutter
所有回贴(35)
2007-03-28 16:32
齿轮机构 gear 齿轮轮坯 blank 齿轮传动系 pinion unit 齿轮联轴器 gear coupling 齿条传动 rack gear 齿数 tooth number 齿数比 gear ratio 齿条 rack 齿条插刀 rack cutter; rack-shaped shaper cutter 齿形链、无声链 silent chain 齿形系数 form factor 齿式棘轮机构 tooth ratchet mechanism 插齿机 gear shaper 重合点 coincident points 重合度 contact ratio 冲床 punch 传动比 transmission ratio, speed ratio 传动装置 gearing; transmission gear 传动系统 driven system 传动角 transmission angle 传动轴 transmission shaft 串联式组合 combination in series 串联式组合机构 series combined mechanism 串级调速 cascade speed control 创新 innovation ; creation 创新设计 creation design 垂直载荷、法向载荷 normal load 唇形橡胶密封 lip rubber seal 磁流体轴承 magnetic fluid bearing 从动带轮 driven pulley 从动件 driven link, follower 从动件平底宽度 width of flat-face 从动件停歇 follower dwell 从动件运动规律 follower motion 从动轮 driven gear 粗线 bold line 粗牙螺纹 coarse thread 大齿轮 gear wheel 打包机 packer 打滑 slipping 带传动 belt driving 带轮 belt pulley 带式制动器 band brake 单列轴承 single row bearing 单向推力轴承 single-direction thrust bearing 单万向联轴节 single universal joint 单位矢量 unit vector 当量齿轮 equivalent spur gear; virtual gear 当量齿数 equivalent teeth number; virtual number of teeth当量摩擦系数 equivalent coefficient of friction 当量载荷 equivalent load 刀具 cutter 导数 derivative 倒角 chamfer 导热性 conduction of heat 导程 lead 导程角 lead angle 等加等减速运动规律 parabolic motion; constant acceleration and deceleration motion 等速运动规律 uniform motion; constant velocity motion 等径凸轮 conjugate yoke radial cam 等宽凸轮 constant-breadth cam 等效构件 equivalent link 等效力 equivalent force 等效力矩 equivalent moment of force 等效量 equivalent 等效质量 equivalent mass 等效转动惯量 equivalent moment of inertia 等效动力学模型 dynamically equivalent model 底座 chassis 低副 lower pair 点划线 chain dotted line (疲劳)点蚀 pitting 垫圈 gasket 垫片密封 gasket seal 碟形弹簧 belleville spring 动力学 dynamics 顶隙 bottom clearance 定轴轮系 ordinary gear train; gear train with fixed axes 动密封 kinematical seal 动能 dynamic energy 动力粘度 dynamic viscosity 动力润滑 dynamic lubrication 动平衡 dynamic balance 动平衡机 dynamic balancing machine 动态特性 dynamic characteristics 动态分析设计 dynamic analysis design 动压力 dynamic reaction 动载荷 dynamic load 端面 transverse plane 端面参数 transverse parameters 端面齿距 transverse circular pitch 端面齿廓 transverse tooth profile 端面重合度 transverse contact ratio 端面模数 transverse module
2007-03-28 16:34
端面压力角 transverse pressure angle 锻造 forge 对称循环应力 symmetry circulating stress 对心滚子从动件 radial (or in-line ) roller follower 对心直动从动件 radial (or in-line ) translating follower对心移动从动件 radial reciprocating follower 对心曲柄滑块机构 in-line slider-crank (or crank-slider) mechanism多列轴承 multi-row bearing 多楔带 poly V-belt 多项式运动规律 polynomial motion 多质量转子 rotor with several masses 惰轮 idle gear 额定寿命 rating life 额定载荷 load rating II 级杆组 dyad 发生线 generating line 发生面 generating plane 法面 normal plane 法面参数 normal parameters 法面齿距 normal circular pitch 法面模数 normal module 法面压力角 normal pressure angle 法向齿距 normal pitch 法向齿廓 normal tooth profile 法向直廓蜗杆 straight sided normal worm 法向力 normal force 反馈式组合 feedback combining 反向运动学 inverse ( or backward) kinematics 反转法 kinematic inversion 反正切 Arctan 范成法 generating cutting 仿形法 form cutting 方案设计、概念设计 concept design, CD 防振装置 shockproof device 飞轮 flywheel 飞轮矩 moment of flywheel 非标准齿轮 nonstandard gear 非接触式密封 non-contact seal 非周期性速度波动 aperiodic speed fluctuation 非圆齿轮 non-circular gear 粉末合金 powder metallurgy 分度线 reference line; standard pitch line 分度圆 reference circle; standard (cutting) pitch circle分度圆柱导程角 lead angle at reference cylinder 分度圆柱螺旋角 helix angle at reference cylinder 分母 denominator 分子 numerator 分度圆锥 reference cone; standard pitch cone 分析法 analytical method 封闭差动轮系 planetary differential 复合铰链 compound hinge 复合式组合 compound combining 复合轮系 compound (or combined) gear train 复合平带 compound flat belt 复合应力 combined stress 复式螺旋机构 Compound screw mechanism 复杂机构 complex mechanism 杆组 Assur group 干涉 interference 刚度系数 stiffness coefficient 刚轮 rigid circular spline 钢丝软轴 wire soft shaft 刚体导引机构 body guidance mechanism 刚性冲击 rigid impulse (shock) 刚性转子 rigid rotor 刚性轴承 rigid bearing 刚性联轴器 rigid coupling 高度系列 height series 高速带 high speed belt 高副 higher pair 格拉晓夫定理 Grashoff`s law 根切 undercutting 公称直径 nominal diameter 高度系列 height series 功 work 工况系数 application factor 工艺设计 technological design 工作循环图 working cycle diagram 工作机构 operation mechanism 工作载荷 external loads 工作空间 working space 工作应力 working stress 工作阻力 effective resistance 工作阻力矩 effective resistance moment 公法线 common normal line 公共约束 general constraint 公制齿轮 metric gears 功率 power 功能分析设计 function analyses design 共轭齿廓 conjugate profiles 共轭凸轮 conjugate cam 构件 link 鼓风机 blower 固定构件 fixed link; frame
2007-03-28 16:35
固体润滑剂 solid lubricant 关节型操作器 jointed manipulator 惯性力 inertia force 惯性力矩 moment of inertia ,shaking moment 惯性力平衡 balance of shaking force 惯性力完全平衡 full balance of shaking force 惯性力部分平衡 partial balance of shaking force 惯性主矩 resultant moment of inertia 惯性主失 resultant vector of inertia 冠轮 crown gear 广义机构 generation mechanism 广义坐标 generalized coordinate 轨迹生成 path generation 轨迹发生器 path generator 滚刀 hob 滚道 raceway 滚动体 rolling element 滚动轴承 rolling bearing 滚动轴承代号 rolling bearing identification code 滚针 needle roller 滚针轴承 needle roller bearing 滚子 roller 滚子轴承 roller bearing 滚子半径 radius of roller 滚子从动件 roller follower 滚子链 roller chain 滚子链联轴器 double roller chain coupling 滚珠丝杆 ball screw 滚柱式单向超越离合器 roller clutch 过度切割 undercutting 函数发生器 function generator 函数生成 function generation 含油轴承 oil bearing 耗油量 oil consumption 耗油量系数 oil consumption factor 赫兹公式 H. Hertz equation 合成弯矩 resultant bending moment 合力 resultant force 合力矩 resultant moment of force 黑箱 black box 横坐标 abscissa 互换性齿轮 interchangeable gears 花键 spline 滑键、导键 feather key 滑动轴承 sliding bearing 滑动率 sliding ratio 滑块 slider 环面蜗杆 toroid helicoids worm 环形弹簧 annular spring 缓冲装置 shocks; shock-absorber 灰铸铁 grey cast iron 回程 return 回转体平衡 balance of rotors 混合轮系 compound gear train 积分 integrate 机电一体化系统设计 mechanical-electrical integration system design 机构 mechanism 机构分析 analysis of mechanism 机构平衡 balance of mechanism 机构学 mechanism 机构运动设计 kinematic design of mechanism 机构运动简图 kinematic sketch of mechanism 机构综合 synthesis of mechanism 机构组成 constitution of mechanism 机架 frame, fixed link 机架变换 kinematic inversion 机器 machine 机器人 robot 机器人操作器 manipulator 机器人学 robotics 技术过程 technique process 技术经济评价 technical and economic evaluation 技术系统 technique system 机械 machinery 机械创新设计 mechanical creation design, MCD 机械系统设计 mechanical system design, MSD 机械动力分析 dynamic analysis of machinery 机械动力设计 dynamic design of machinery 机械动力学 dynamics of machinery 机械的现代设计 modern machine design 机械系统 mechanical system 机械利益 mechanical advantage 机械平衡 balance of machinery 机械手 manipulator 机械设计 machine design; mechanical design 机械特性 mechanical behavior 机械调速 mechanical speed governors 机械效率 mechanical efficiency 机械原理 theory of machines and mechanisms 机械运转不均匀系数 coefficient of speed fluctuation 机械无级变速 mechanical stepless speed changes 基础机构 fundamental mechanism 基本额定寿命 basic rating life 基于实例设计 case-based design,CBD
2007-03-28 16:38
基圆 base circle 基圆半径 radius of base circle 基圆齿距 base pitch 基圆压力角 pressure angle of base circle 基圆柱 base cylinder 基圆锥 base cone 急回机构 quick-return mechanism 急回特性 quick-return characteristics 急回系数 advance-to return-time ratio 急回运动 quick-return motion 棘轮 ratchet 棘轮机构 ratchet mechanism 棘爪 pawl 极限位置 extreme (or limiting) position 极位夹角 crank angle between extreme (or limiting) positions计算机辅助设计 computer aided design, CAD 计算机辅助制造 computer aided manufacturing, CAM 计算机集成制造系统 computer integrated manufacturing system, CIMS 计算力矩 factored moment; calculation moment 计算弯矩 calculated bending moment 加权系数 weighting efficient 加速度 acceleration 加速度分析 acceleration analysis 加速度曲线 acceleration diagram 尖点 pointing; cusp 尖底从动件 knife-edge follower 间隙 backlash 间歇运动机构 intermittent motion mechanism 减速比 reduction ratio 减速齿轮、减速装置 reduction gear 减速器 speed reducer 减摩性 anti-friction quality 渐开螺旋面 involute helicoids 渐开线 involute 渐开线齿廓 involute profile 渐开线齿轮 involute gear 渐开线发生线 generating line of involute 渐开线方程 involute equation 渐开线函数 involute function 渐开线蜗杆 involute worm 渐开线压力角 pressure angle of involute 渐开线花键 involute spline 简谐运动 simple harmonic motion 键 key 键槽 keyway 交变应力 repeated stress 交变载荷 repeated fluctuating load 交叉带传动 cross-belt drive 交错轴斜齿轮 crossed helical gears 胶合 scoring 角加速度 angular acceleration 角速度 angular velocity 角速比 angular velocity ratio 角接触球轴承 angular contact ball bearing 角接触推力轴承 angular contact thrust bearing 角接触向心轴承 angular contact radial bearing 角接触轴承 angular contact bearing 铰链、枢纽 hinge 校正平面 correcting plane 接触应力 contact stress 接触式密封 contact seal 阶梯轴 multi-diameter shaft 结构 structure 结构设计 structural design 截面 section 节点 pitch point 节距 circular pitch; pitch of teeth 节线 pitch line 节圆 pitch circle 节圆齿厚 thickness on pitch circle 节圆直径 pitch diameter 节圆锥 pitch cone 节圆锥角 pitch cone angle 解析设计 analytical design 紧边 tight-side 紧固件 fastener 径节 diametral pitch 径向 radial direction 径向当量动载荷 dynamic equivalent radial load 径向当量静载荷 static equivalent radial load 径向基本额定动载荷 basic dynamic radial load rating径向基本额定静载荷 basic static radial load tating 径向接触轴承 radial contact bearing 径向平面 radial plane 径向游隙 radial internal clearance 径向载荷 radial load 径向载荷系数 radial load factor 径向间隙 clearance 静力 static force 静平衡 static balance 静载荷 static load 静密封 static seal
2007-03-28 16:40
局部自由度 passive degree of freedom 矩形螺纹 square threaded form 锯齿形螺纹 buttress thread form 矩形牙嵌式离合器 square-jaw positive-contact clutch 绝对尺寸系数 absolute dimensional factor 绝对运动 absolute motion 绝对速度 absolute velocity 均衡装置 load balancing mechanism 抗压强度 compression strength 开口传动 open-belt drive 开式链 open kinematic chain 开链机构 open chain mechanism 可靠度 degree of reliability 可靠性 reliability 可靠性设计 reliability design, RD 空气弹簧 air spring 空间机构 spatial mechanism 空间连杆机构 spatial linkage 空间凸轮机构 spatial cam 空间运动副 spatial kinematic pair 空间运动链 spatial kinematic chain 框图 block diagram 空转 idle 宽度系列 width series 雷诺方程 Reynolds‘s equation 离心力 centrifugal force 离心应力 centrifugal stress 理论廓线 pitch curve 离合器 clutch 离心密封 centrifugal seal理论啮合线 theoretical line of action 隶属度 membership 力 force 力多边形 force polygon 力封闭型凸轮机构 force-drive (or force-closed) cam mechanism 力矩 moment 力平衡 equilibrium 力偶 couple 力偶矩 moment of couple 连杆 connecting rod, coupler 连杆机构 linkage 连杆曲线 coupler-curve 连心线 line of centers 链 chain 链传动装置 chain gearing 链轮 sprocket ; sprocket-wheel ; sprocket gear ; chain wheel 联组 V 带 tight-up V belt 联轴器 coupling ; shaft coupling 两维凸轮 two-dimensional cam 临界转速 critical speed 六杆机构 six-bar linkage 龙门刨床 double Haas planer 轮坯 blank 轮系 gear train 螺杆 screw 螺距 thread pitch 螺母 screw nut 螺旋锥齿轮 helical bevel gear 螺钉 screws 螺栓 bolts 螺纹导程 lead 螺纹效率 screw efficiency 螺旋传动 power screw 螺旋密封 spiral seal 螺纹 thread (of a screw) 螺旋副 helical pair 螺旋机构 screw mechanism 螺旋角 helix angle 螺旋线 helix ,helical line 绿色设计 green design ; design for environment 马耳他机构 Geneva wheel ; Geneva gear 马耳他十字 Maltese cross 脉动无级变速 pulsating stepless speed changes 脉动循环应力 fluctuating circulating stress 脉动载荷 fluctuating load 铆钉 rivet 迷宫密封 labyrinth seal 密封 seal 密封带 seal belt 密封胶 seal gum 密封元件 potted component 密封装置 sealing arrangement 面对面安装 face-to-face arrangement 面向产品生命周期设计 design for product`s life cycle, DPLC名义应力、公称应力 nominal stress 模块化设计 modular design, MD 模块式传动系统 modular system 模幅箱 morphology box 模糊集 fuzzy set 模糊评价 fuzzy evaluation 模数 module 摩擦 friction 摩擦角 friction angle 摩擦力 friction force 摩擦学设计 tribology design, TD
2007-03-28 16:48
摩擦阻力 frictional resistance 摩擦力矩 friction moment 摩擦系数 coefficient of friction 摩擦圆 friction circle 磨损 abrasion ;wear; scratching 末端执行器 end-effector 目标函数 objective function 耐腐蚀性 corrosion resistance 耐磨性 wear resistance 内齿轮 internal gear 挠性机构 mechanism with flexible elements 挠性转子 flexible rotor内齿圈 ring gear 内力 internal force 内圈 inner ring 能量 energy 能量指示图 viscosity 逆时针 counterclockwise (or anticlockwise) 啮出 engaging-out 啮合 engagement, mesh, gearing 啮合点 contact points 啮合角 working pressure angle 啮合线 line of action 啮合线长度 length of line of action 啮入 engaging-in 牛头刨床 shaper 凝固点 freezing point; solidifying point 扭转应力 torsion stress 扭矩 moment of torque 扭簧 helical torsion spring 诺模图 Nomogram O 形密封圈密封 O ring seal 盘形凸轮 disk cam 盘形转子 disk-like rotor 抛物线运动 parabolic motion 疲劳极限 fatigue limit 疲劳强度 fatigue strength 偏置式 offset 偏 ( 心 ) 距 offset distance 偏心率 eccentricity ratio 偏心质量 eccentric mass 偏距圆 offset circle 偏心盘 eccentric 偏置滚子从动件 offset roller follower 偏置尖底从动件 offset knife-edge follower 偏置曲柄滑块机构 offset slider-crank mechanism 拼接 matching 评价与决策 evaluation and decision 平底宽度 face width 频率 frequency 平带 flat belt 平带传动 flat belt driving 平底从动件 flat-face follower 平分线 bisector 平均应力 average stress 平均中径 mean screw diameter 平均速度 average velocity 平衡 balance 平衡机 balancing machine 平衡品质 balancing quality 平衡平面 correcting plane 平衡质量 balancing mass 平衡重 counterweight 平衡转速 balancing speed 平面副 planar pair, flat pair 平面机构 planar mechanism 平面运动副 planar kinematic pair 平面连杆机构 planar linkage 平面凸轮 planar cam 平面凸轮机构 planar cam mechanism 平面轴斜齿轮 parallel helical gears 普通平键 parallel key 其他常用机构 other mechanism in common use 起动阶段 starting period 启动力矩 starting torque 气动机构 pneumatic mechanism 奇异位置 singular position 起始啮合点 initial contact , beginning of contact 气体轴承 gas bearing 千斤顶 jack 嵌入键 sunk key 强迫振动 forced vibration 切齿深度 depth of cut 曲柄 crank 曲柄存在条件 Grashoff`s law 曲柄导杆机构 crank shaper (guide-bar) mechanism 曲柄滑块机构 slider-crank (or crank-slider) mechanism 曲柄摇杆机构 crank-rocker mechanism 曲齿锥齿轮 spiral bevel gear 曲率 curvature 曲率半径 radius of curvature 曲面从动件 curved-shoe follower 曲线拼接 curve matching 曲线运动 curvilinear motion 曲轴 crank shaft
2007-03-28 16:52
驱动力 driving force 驱动力矩 driving moment (torque) 全齿高 whole depth 权重集 weight sets 球 ball 球面滚子 convex roller 球轴承 ball bearing 球面副 spheric pair 球面渐开线 spherical involute 球面运动 spherical motion 球销副 sphere-pin pair 球坐标操作器 polar coordinate manipulator 燃点 spontaneous ignition 热平衡 heat balance; thermal equilibrium 人字齿轮 herringbone gear 冗余自由度 redundant degree of freedom 柔轮 flexspline 柔性冲击 flexible impulse; soft shock 柔性制造系统 flexible manufacturing system; FMS 柔性自动化 flexible automation 润滑油膜 lubricant film 润滑装置 lubrication device 润滑 lubrication 润滑剂 lubricant 三角形花键 serration spline 三角形螺纹 V thread screw 三维凸轮 three-dimensional cam 三心定理 Kennedy`s theorem 砂轮越程槽 grinding wheel groove 砂漏 hour-glass 少齿差行星传动 planetary drive with small teeth difference设计方法学 design methodology 设计变量 design variable 设计约束 design constraints 深沟球轴承 deep groove ball bearing 生产阻力 productive resistance 升程 rise 升距 lift 实际廓线 cam profile 十字滑块联轴器 double slider coupling; Oldham‘s coupling 矢量 vector 输出功 output work 输出构件 output link 输出机构 output mechanism 输出力矩 output torque 输出轴 output shaft 输入构件 input link 数学模型 mathematic model 实际啮合线 actual line of action 双滑块机构 double-slider mechanism, ellipsograph 双曲柄机构 double crank mechanism 双曲面齿轮 hyperboloid gear 双头螺柱 studs 双万向联轴节 constant-velocity (or double) universal joint 双摇杆机构 double rocker mechanism 双转块机构 Oldham coupling 双列轴承 double row bearing 双向推力轴承 double-direction thrust bearing 松边 slack-side 顺时针 clockwise 瞬心 instantaneous center 死点 dead point 四杆机构 four-bar linkage 速度 velocity 速度不均匀 ( 波动 ) 系数 coefficient of speed fluctuation速度波动 speed fluctuation 速度曲线 velocity diagram 速度瞬心 instantaneous center of velocity 塔轮 step pulley 踏板 pedal 台钳、虎钳 vice 太阳轮 sun gear 弹性滑动 elasticity sliding motion 弹性联轴器 elastic coupling ; flexible coupling 弹性套柱销联轴器 rubber-cushioned sleeve bearing coupling 套筒 sleeve 梯形螺纹 acme thread form 特殊运动链 special kinematic chain 特性 characteristics 替代机构 equivalent mechanism 调节 modulation, regulation 调心滚子轴承 self-aligning roller bearing 调心球轴承 self-aligning ball bearing 调心轴承 self-aligning bearing 调速 speed governing 调速电动机 adjustable speed motors 调速系统 speed control system 调压调速 variable voltage control 调速器 regulator, governor 铁磁流体密封 ferrofluid seal 停车阶段 stopping phase 停歇 dwell 同步带 synchronous belt 同步带传动 synchronous belt drive
2007-03-28 16:54
凸的,凸面体 convex 凸轮 cam 凸轮倒置机构 inverse cam mechanism 凸轮机构 cam , cam mechanism 凸轮廓线 cam profile 凸轮廓线绘制 layout of cam profile 凸轮理论廓线 pitch curve 凸缘联轴器 flange coupling 图册、图谱 atlas 图解法 graphical method 推程 rise 推力球轴承 thrust ball bearing 推力轴承 thrust bearing 退刀槽 tool withdrawal groove 退火 anneal 陀螺仪 gyroscope V 带 V belt 外力 external force 外圈 outer ring 外形尺寸 boundary dimension 万向联轴器 Hooks coupling ; universal coupling 外齿轮 external gear 弯曲应力 beading stress 弯矩 bending moment 腕部 wrist 往复移动 reciprocating motion 往复式密封 reciprocating seal 网上设计 on-net design, OND 微动螺旋机构 differential screw mechanism 位移 displacement 位移曲线 displacement diagram 位姿 pose , position and orientation 稳定运转阶段 steady motion period 稳健设计 robust design 蜗杆 worm 蜗杆传动机构 worm gearing 蜗杆头数 number of threads 蜗杆直径系数 diametral quotient 蜗杆蜗轮机构 worm and worm gear 蜗杆形凸轮步进机构 worm cam interval mechanism 蜗杆旋向 hands of worm 蜗轮 worm gear 涡圈形盘簧 power spring 无级变速装置 stepless speed changes devices 无穷大 infinite 系杆 crank arm, planet carrier 现场平衡 field balancing 向心轴承 radial bearing 向心力 centrifugal force 相对速度 relative velocity 相对运动 relative motion 相对间隙 relative gap 象限 quadrant 橡皮泥 plasticine 细牙螺纹 fine threads 销 pin 消耗 consumption 小齿轮 pinion 小径 minor diameter 橡胶弹簧 balata spring 修正梯形加速度运动规律 modified trapezoidal acceleration motion 修正正弦加速度运动规律 modified sine acceleration motion 斜齿圆柱齿轮 helical gear 斜键、钩头楔键 taper key 泄漏 leakage 谐波齿轮 harmonic gear 谐波传动 harmonic driving 谐波发生器 harmonic generator 斜齿轮的当量直齿轮 equivalent spur gear of the helical gear 心轴 spindle 行程速度变化系数 coefficient of travel speed variation 行程速比系数 advance-to return-time ratio 行星齿轮装置 planetary transmission 行星轮 planet gear 行星轮变速装置 planetary speed changing devices 行星轮系 planetary gear train 形封闭凸轮机构 positive-drive (or form-closed) cam mechanism 虚拟现实 virtual reality 虚拟现实技术 virtual reality technology, VRT 虚拟现实设计 virtual reality design, VRD 虚约束 redundant (or passive) constraint 许用不平衡量 allowable amount of unbalance 许用压力角 allowable pressure angle 许用应力 allowable stress; permissible stress 悬臂结构 cantilever structure 悬臂梁 cantilever beam 循环功率流 circulating power load 旋转力矩 running torque 旋转式密封 rotating seal 旋转运动 rotary motion
2007-03-28 16:56
选型 type selection 压力 pressure 压力中心 center of pressure 压缩机 compressor 压应力 compressive stress 压力角 pressure angle 牙嵌式联轴器 jaw (teeth) positive-contact coupling 雅可比矩阵 Jacobi matrix 摇杆 rocker 液力传动 hydrodynamic drive 液力耦合器 hydraulic couplers 液体弹簧 liquid spring 液压无级变速 hydraulic stepless speed changes 液压机构 hydraulic mechanism 一般化运动链 generalized kinematic chain 移动从动件 reciprocating follower 移动副 prismatic pair, sliding pair 移动关节 prismatic joint 移动凸轮 wedge cam 盈亏功 increment or decrement work 应力幅 stress amplitude 应力集中 stress concentration 应力集中系数 factor of stress concentration 应力图 stress diagram 应力 — 应变图 stress-strain diagram 优化设计 optimal design 油杯 oil bottle 油壶 oil can 油沟密封 oily ditch seal 有害阻力 useless resistance 有益阻力 useful resistance 有效拉力 effective tension 有效圆周力 effective circle force 有害阻力 detrimental resistance 余弦加速度运动 cosine acceleration (or simple harmonic) motion 预紧力 preload 原动机 primer mover 圆带 round belt 圆带传动 round belt drive 圆弧齿厚 circular thickness 圆弧圆柱蜗杆 hollow flank worm 圆角半径 fillet radius 圆盘摩擦离合器 disc friction clutch 圆盘制动器 disc brake 原动机 prime mover 原始机构 original mechanism 圆形齿轮 circular gear 圆柱滚子 cylindrical roller 圆柱滚子轴承 cylindrical roller bearing 圆柱副 cylindric pair 圆柱式凸轮步进运动机构 barrel (cylindric) cam 圆柱螺旋拉伸弹簧 cylindroid helical-coil extension spring 圆柱螺旋扭转弹簧 cylindroid helical-coil torsion spring 圆柱螺旋压缩弹簧 cylindroid helical-coil compression spring 圆柱凸轮 cylindrical cam 圆柱蜗杆 cylindrical worm 圆柱坐标操作器 cylindrical coordinate manipulator 圆锥螺旋扭转弹簧 conoid helical-coil compression spring 圆锥滚子 tapered roller 圆锥滚子轴承 tapered roller bearing 圆锥齿轮机构 bevel gears 圆锥角 cone angle 原动件 driving link 约束 constraint 约束条件 constraint condition 约束反力 constraining force 跃度 jerk 跃度曲线 jerk diagram 运动倒置 kinematic inversion 运动方案设计 kinematic precept design 运动分析 kinematic analysis 运动副 kinematic pair 运动构件 moving link 运动简图 kinematic sketch 运动链 kinematic chain 运动失真 undercutting 运动设计 kinematic design 运动周期 cycle of motion 运动综合 kinematic synthesis 运转不均匀系数 coefficient of velocity fluctuation 运动粘度 kenematic viscosity 载荷 load 载荷 — 变形曲线 load—deformation curve 载荷 — 变形图 load—deformation diagram
2007-03-28 17:01
